While I hope for both of those aspects, my focus is on the former. I'd just really like them to repackage the exhaust manifolds, so as to get rid of that bodywork bulge. Doing so would also encourage more side-pod over-cut airflow, into the under-cut/cokebottle, onto the floor and over the diffuser:Just_a_fan wrote: ↑14 Feb 2020, 13:58Presumably Cowell means that the aero team can make the bodywork tighter to reduce drag etc. Also, by making more power, more downforce can be carried by the car without diminishing top speed.
I would suggest that if they could do that, they would have. There's a lot of stuff in that region and it needs space. If they make the exhaust too small/convoluted then they will undoubtedly lose power and / or reliability.OO7 wrote: ↑14 Feb 2020, 14:12While I hope for both of those aspects, my focus is on the former. I'd just really like them to get repackage the exhaust manifolds, so as to get rid of that bodywork bulge.Just_a_fan wrote: ↑14 Feb 2020, 13:58Presumably Cowell means that the aero team can make the bodywork tighter to reduce drag etc. Also, by making more power, more downforce can be carried by the car without diminishing top speed.
I hear that Just_a_fan. I understand that it's not a simple task and may not even be possible. One can dream however.Just_a_fan wrote: ↑14 Feb 2020, 15:09I would suggest that if they could do that, they would have. There's a lot of stuff in that region and it needs space. If they make the exhaust too small/convoluted then they will undoubtedly lose power and / or reliability.
James Allison reckoned they'd both reduced drag and increased downforce with the new car.
Any increase in compressor efficiency means a decrease in heat rejection to the charge air cooler for the same lambda - charge air cooler can be made smaller.OO7 wrote: ↑14 Feb 2020, 13:53I'm interested in the bolded text particularly.Morteza wrote: ↑14 Feb 2020, 13:12Andy Cowell on 2020 engineAndy Cowell wrote:“We have had to develop an even wider area of the PU. We have looked at every single system,” said Andy Cowell, Managing Director of Mercedes-AMG High Performance Powertrains. “We have worked on a huge array of projects, and when summed together they will hopefully help propel the car around the track quicker and give the aerodynamics team more opportunities to improve as well.”![]()
Allison has stated that the car features larger radiators than last year with a small weight penalty increase.Mudflap wrote: ↑14 Feb 2020, 22:25Any increase in compressor efficiency means a decrease in heat rejection to the charge air cooler for the same lambda - charge air cooler can be made smaller.
Any decrease in friction means less heat rejection to oil - the oil radiator can be made smaller.
Any decrease in combustion walls thermal conductivity means less heat rejected to water - the water radiator can be made smaller.
etc..
Of course all of these also translate into an increase in crank power or a decrease in power to drive in the case of the compressor.
I was giving a generic example. Increasing the radiator area is very unlikely to help with aeroOO7 wrote: ↑14 Feb 2020, 22:29Allison has stated that the car features larger radiators than last year with a small weight penalty increase.Mudflap wrote: ↑14 Feb 2020, 22:25Any increase in compressor efficiency means a decrease in heat rejection to the charge air cooler for the same lambda - charge air cooler can be made smaller.
etc..
I see, thanks.
it's a contradiction isn't it, i've been assuming that the new radiators would've been even bigger without running the coolant hotter, which was quite major as apparently they're running the aluminium parts so hot they're being weakened. So it sounds like they've done the design with this in mind, presumably doing the cooling channels so that the peak temperatures aren't so far from the kind of core temperature - more channels, closer to surfaces, kind of thing
They're seriously pushing the limits and extending themselves, which isn't a bad thing. I really hope all their hard work pays off.Mudflap wrote: ↑17 Feb 2020, 22:34Today Brixworth have held a company wide meeting to present the new power unit.
Rumours are 20 hp up from last season and over 3 tenths quicker from just the engine (of which almost 1 tenth from the cooling inovations that allow the car to run more closed).
All their prove out engines have failed before achieving the target mileage and they are now counting on the engines returning from Barcelona at the end of the test to be used for prove out.
20 hp is the biggest gain since 2014? Seems like one of the rumors must be false.Mudflap wrote: ↑17 Feb 2020, 22:34Today Brixworth have held a company wide meeting to present the new power unit.
