2024 Mclaren Formula 1 Team
mwillems
45
I'd expect the front wing at least.
We may also see a suspension geometry change and the flow conditioners behind the front wheels in the earlier upgrades released.
-Bandit
Tomsky
Tomsky
29
mwillems wrote:
20 Mar 2024, 11:25
To change the geometry of the suspension, you need to pass a crash test. It's unrealistic.
mwillems
45
Tomsky wrote:
20 Mar 2024, 12:05
mwillems wrote:
20 Mar 2024, 11:25
For all elements? It's quite common for front and rear to have changes that ensure airflow can move as freely as possible past the suspension. Mclaren brought mid season changes last year.
Do you know where this is stated in the rules?
-Bandit
trinidefender
trinidefender
318
Tomsky wrote:
20 Mar 2024, 12:05
mwillems wrote:
20 Mar 2024, 11:25
While true in a general practical sense it’s not true in a technical sense. See the Mercedes that built its chassis with multiple mounting points for its front suspension allowing them a wider range of setup options.
But yes, for McLaren and every other team your statement remains true. I only mentioned this in case someone misinterprets what you’re saying and uses the logic incorrectly in the future.
djos
113
Good interview with Oscar just popped up on YouTube.
"In downforce we trust"
SilviuAgo
MCL38 in Australia:
and more form Albert Fabrega
mwillems
45
trinidefender wrote:
20 Mar 2024, 15:02
Tomsky wrote:
20 Mar 2024, 12:05
mwillems wrote:
20 Mar 2024, 11:25
I think it is likely to be for parts fitted to the crash structure or the safety cell, not for every part of the suspension, as minor changes for airflow are made during the year, as they were last year for Mclaren. But if you could post a link to the rules that would be helpful, I'm curious to learn more, perhaps we did crash tests in the middle of the season last year, it may have happened.
-Bandit
geogate
geogate
quite surprised at that rear wing - thought it be medium high, not medium low like that
LionsHeart
LionsHeart
geogate wrote:
21 Mar 2024, 23:23
There are a couple of slow turns, as well as a quick series of high-speed turns where you need to quickly move the steering wheel left and right. Even from the first practice, it was clear how many mistakes there were in this place. Many people lack stability in the rear end. I’m kinda surprised that McLaren didn’t bring the Bahrain spec rear wing here. Yes, it is even more aerodynamically loaded, but stability could be achieved even more.
LionsHeart
LionsHeart
mwillems wrote:
21 Mar 2024, 22:55
20 Mar 2024, 15:02
Tomsky wrote:
20 Mar 2024, 12:05
As much as I’ve been following and studying Formula 1, this is the first time I’ve heard of such a rule. The regulations state that the cables inside the suspension arms must hold the hub, steering knuckle and wheel so that the wheel does not fly off somewhere. Typically, crash tests examine the nose cone, side structures, rear structure and the top of the monocoque. Although I myself have never seen how exactly the upper structure is tested for impact.
On the other hand, there is logic in Tomsky’s words. Changing the geometry of the suspension arms will mean that you will have to re-route the cables and make sure that the wheel does not come off. And this meets direct safety rules. In the past, wheels often flew off and could cause damage. However, they are still flying away. When changing the attachment point, you will have to look for a new point where you will have to attach the cable.
genarro
genarro
how does race pace look? Are we in front of Merc and Aston on race pace?
mwillems
45
LionsHeart wrote:
22 Mar 2024, 04:57
mwillems wrote:
21 Mar 2024, 22:55
20 Mar 2024, 15:02
It does make sense. But as they say, the devil is in the detail.
I can't find anything on the Internet or in the tech regs that supports it, but the regs around crash testing are lengthy and wordy, I have probably missed it. Like you it is the first time I heard it, so want to learn the detail.
All I can see is that it says any significant modification requires retesting. I can't see where the significance is defined.
Edit: It also says only calculations on.load for parts directly attached to the survival cell and behind . XA=250 are required this is what I was suggesting. No rules on the tether specifically.
Suspension does need to be attached during testing if attached to the rear impact structure. There is nothing in the rules mandating the testing of the front suspension as far as I can see.
So the mounting points on the gearbox casing are also not subject to retest if changed.
There appears to be decent freedom to change these points in season and within reason, which is why it is not uncommon to see it.
Merc moved theirs at the front in their Monaco update last year and left the old mounting points on.
It was not a new crash tested area, otherwise they'd shed the weight and ditch the old mounting point.
-Bandit
_cerber1
268
genarro wrote:
22 Mar 2024, 09:38
CjC
CjC
Sorry to dampen things but Piastri had a strong long run in Bahrain FP2 too…
However it looks to me that Piastri has definitely sharpened his pencil for this season which I think we all expected he would👍🏻
Just a fan's point of view
Emag
Emag
109
Oscar has really stepped it up this year. Impressed with him. He was faster than Lando in Saudi, and almost neck and neck in Bahrain, which is a very high deg track and experience is invaluable.
He seems to be very competitive here in home soil as well.
Developer of F1InsightsHub
