2018 pre-season testing thread
Re: 2018 pre-season testing thread
Mr.G wrote:
13 Mar 2018, 16:49
Just_a_fan wrote:
13 Mar 2018, 16:47
GoranF1 wrote:
12 Mar 2018, 19:58
Last day of testing
https://twitter.com/alo_pumpa/status/97 ... 76166?s=19
Hamilton's very low top speed indicative of a driver backing off on the main straight aka sandbagging?
Or driving to a delta...
Perhaps but that usually involves driving the whole lap slightly slowly. By backing off hard on the straight, you kill the lap time but still get to drive quickly in the corners. That gives better simulation of tyre wear, stresses on the car etc.
zac510 wrote:
13 Mar 2018, 16:57
Interesting conversation topic.
Just_a_fan wrote:
13 Mar 2018, 16:46
I wonder if the burn outs were a way of trying to simulate very worn tyres by, well, wearing them out quickly. Perhaps trying to see what the drop off in performance was and whether they can make a very tired tyre last. Can't see why else you would do it, to be honest.
Especially when fronts would not be worn equally. You'd just end up with an imbalanced set of tyres, maybe not representative of a real set of tyres that have done a stint.
Depends on whether your car is front or rear limited in terms of wear. Perhaps they're trying to see whether they have inherited last season's rear tyre issues.
JonoNic
Just_a_fan wrote:
Mr.G wrote:
13 Mar 2018, 16:49
Just_a_fan wrote:
13 Mar 2018, 16:47
Lift and coast is normally used to save fuel. Wouldn't driving slightly slower have the same effect and therefore skewing information that teams are receiving?
Sent from my SM-A520F using Tapatalk
Always find the gap then use it.
I would imagine Merc were more trying to see what sort of heat cycling the US needed for best tyre life, and probably grip at the start - as it looks like they're intent on using quite a few.
Mr.G
34
JonoNic wrote:
13 Mar 2018, 17:34
Just_a_fan wrote:
Mr.G wrote:
13 Mar 2018, 16:49
No, as this is Mercedes and such think is not acceptable by the public opinion :) If Mercedes is lifting it must be sandbagging or something secret :D
Blistering on tyres caused by rolling burnout is also, in a way, a message to Pirelli - look what's happening, don't bring them to races too often. It wouldn't be the first time for Mercedes to put pressure on Pirelli. In 2013 Red Bull and Mercedes had fast cars, but also cars which chewed their tyres faster than opposition (Ferrari and Lotus). From the first winter test those 2 teams kept saying tyres need to change, until excessive tyre defects eventually made Pirelli change tyre construction (and compounds I think, not sure).
As first races showed, Ferrari and Lotus were able to nurse their tyres a lot better than than rival teams, so Merc and Red Bull stepped on it even more. Pirelli's tyres were awful at the time, it goes without saying. But the pressure to change them by those two teams was immense and came from poor results. After the change in tyre construction, only Red Bull and Mercedes won races, with Ferrari and Lotus barely reaching a podium from time to time. Alonso won 2 races before this tyre change, with unfortunate races in Malaysia and Bahrain where he would have been in the fight as well.
Just something to include in this discussion, this is not something new for Mercedes at all.
ema00
ema00
TAG wrote:
13 Mar 2018, 15:00
In the better late than never department:
There were a few times that we heard over the testing days that Mercedes were doing "rolling burnouts" driving through pit lane and I wanted to discuss this since it was never delved deeper into. Now I have a very good idea at what a rolling burnout is, why a team would do that (only Mercedes) is open for debate, but we saw lots and lots of pictures with the Merc's tires absolutely blistered to the brink.
http://a.espncdn.com/combiner/i?img=%2F ... .jpg&w=570
So my thought of what a rolling burnout is; Mercedes in the middle of a stint would pit and then launch through the lane, doing the same kinds of burnout we all grew up as kids doings. Is my interpretation of this off base? In the years I've been following the sport I've never heard is reported of a team doing something like this.
I ask, because the tire choices per driver for Melbourne are released now and the tea leaves are ripe for the reading.
maybe Vettel has the answer
Parlando di gomme, il “blistering” potrebbe essere un problema?
“Penso sia normale che, dopo i primi giorni di test, ogni squadra cerchi di portare il fornitore di gomme nella direzione che più si adatta alla propria vettura. Da parte nostra, pensiamo che la Pirelli abbia fatto un buon lavoro con la sua gamma di mescole”.
G: Talking about tyres, could blistering be a problem?
SV: I think that, after a few days of test, is normal for each team to try to bring Pirelli on the way that better suits to its car
Mr.G
34
I've recently read an article, where Vettel was pointing out that Mercedes during the race simulation used only medium tyres and not two different types of tyres as mandatory in race. Isn't this something that should be represented in the analyses that tray to find the pecking order?
marmer
marmer
Could it just be a case of getting hear into the tyre due to colder than normal temperature at least for the first test
dans79
267
Mr.G wrote:
13 Mar 2018, 22:24
If you go back and look several of us took that into account with are calculations.
201 105 104 9 9 7
atanatizante
121
Just_a_fan wrote:
13 Mar 2018, 16:46
I`ve read that Lewis run all day long without DRS on ...
This could be right coz delta speed - between switch on and off DRS - is somewhere at 20km/h on average, hence 308 + 20 means 328 which is 6 km/h less than what Bottas did with his top speed of 334 km/h ...
Maybe the latter was running with DRS, maybe he had a slip stream or maybe even his RW has had a slighter lower AoA for higher top speed ... other strat mode is out of the question ...
What about PU endurance test?
For 7 weekends they could reach almost 5400km or so, had I`m not wrong on my calculation ... and Merc team only did 3800km or so in those 8 days ...
Jesus
HPD
198
Nothing more to say.. :arrow:
First, let's take a look at the absolute top speeds. Mercedes leads the ranking with 334.3 km / h.
At the other end of the table is McLaren. We are used to that. But can not point to Honda with his finger. The papaya-yellow cars are powered by Renault engines. That leaves only the conclusion that the McLaren MCL33 is fully designed for contact pressure.
Fernando Alonso drove the peak of 317.6 km / h at the conclusion of his round of cheating when he shortened the chicane. In his fastest lap of 1.17,784 minutes Alonso was measured with 315.7 km / h. The Spaniard was traveling with open DRS. That's all his McLaren gave.
Toro Rosso landed with 324.3 km / h in good midfield. So bad can not be the Honda engine so. Also Pierre Gasly's 287.2 km / h on the finish line can be seen. Honda has not only made his drive more stable, but on stronger.
Therefore, we compared the two values of the four engine manufacturers on the lap in which the highest speeds were determined. As already mentioned, the delta is a good indicator of how much the electric drive contributes to overall performance. Ferrari won 56.7 km / h. More than Mercedes, which have brought it to 53.1 km / h.
Renault lies with a 54.5 km / h Delta in between. Readout at Verstappens record of Thursday with 327.2 km / h at the end of the home straight and 272.7 km / h on the finish line. That was more realistic than his Monday show. Even Honda is not miles away with a difference of 50.2 km / h. What proves: Electrically, the opponents of Mercedes have caught up.
More: https://www.auto-motor-und-sport.de/for ... isch%29%29
Joseki
Joseki
Max Verstappen Red Bull 331,2 km/h 285,5 km/h 45,7 km/h
Daniel Ricciardo Red Bull 318,5 km/h 284,2 km/h 34,3 km/h
Fernando Alonso McLaren 317,6 km/h 286,4 km/h 31,2 km/h
Big Tea
99
This last couple of years Hamilton has been complaining about his tyres, balance etc, could Merc be testing some sort of self compensating device/system for tyre problems?
Could be the best way to get a random unbalanced tyre is to blister them?
If they are trying to compensate for random but repetitive problems would this be as good a way as any?
TAG
I'm reading a lot of conspiracy theories and unsubstantiated claims, not really the way to answer a question certainly not really a way to further a logical reason based discussion.
Last year's tire issue with Mercedes had everything to do with the FRIC suspension being banned before the beginning of the season. Mercedes clearly got around those issues to some degree in the second part of the season, but they still suffered in colder temps and in tracks that required high downforce.
If anyone thinks that Mercedes wouldn't have spent the entire development season coming up with ways to mitigate what proved to be the car's only flaw, you are underestimating the team's ability by a long shot.
Lastly, I'll leave you guys this this, James Allison has a long history making F1 cars that are gentle on tires. Kimi's owes the last win of his career to him. I'm thinking Mercedes will go longer on tires this year than any other team, and they'll have gotten rid of all of the mulligan circuits they struggled with last year. We won't have long to wait to see which way this turns out.
माकडाच्या हाती कोलीत
