George-Jung wrote:WilliamsF1 wrote:How can the car be set for oversteer?
I always thought it was about adding more front end grip with higher front wing angles or reduced rear wing angles and having a more aggressive front suspension setting.
Toe settings, Camber settings, damper settings, ride height etc..
When someone says that the F14T is designed for Alonso and not Kimi, what does that mean?
Even the regulations do not allow for a weight distribution of more than 46.7% (previous years) over the front axil, so how does one design a car for Kimi?
The car has the following problems to start with:
1) Rear comes loose on entry into a corner (sudden loss of down force)
2) on exit car looses traction (sudden surge of engine power)
