McLaren MCL34 speculation thread
Re: McLaren MCL34 speculation thread
Probably a bonded nut in the composite on the other side, the bolt is likely to be an Unbrako 12.9 or 14.9 - they're the go to for things that aren't having custom fasteners for F1, anything lower spec is extra weight for nothing, and SCC isn't really a concern at all.
BassVirolla
godlameroso wrote:
08 Feb 2019, 18:57
M840TR wrote:
08 Feb 2019, 18:55
godlameroso wrote:
08 Feb 2019, 16:31
Do those fasteners use a nut on the other side? Looks to be a 5mm Allen head 10.8 grade fastener. Torque spec on something like that is probably 8.7ft lbs.
It does look like his fingers are grasping something on the so probably yeah.
I often wonder if weight is considered when choosing bolt and nut combo vs studs, or self locking washers, and if propensity for loosening due to vibrations is also considered.
Taking weight and vibrations in condideration, there's nothing better than anaerobic adhesives / sealants.
In aeronautics, specially in turbine engines, is usual to make extensive the use of titanium in bolts and nuts (as in compressor / fan blades).
proteus
22
I am far away from top mechanical engineering, but this looks like an aluminium washer used between the nut and the bolt to me. The same way that cars have it at the oil collector on the bottom.
ThePapayaJaguar
ThePapayaJaguar
M840TR wrote:
08 Feb 2019, 14:29
Another sneak peek
https://i.imgur.com/8OfV3ln.jpg
https://i.imgur.com/u0lpbrM.jpg
Any idea where the picture with Pat and Gil was taken from?
_cerber1
269
The first thing that comes to mind is the inlet in the engine cover.
F1NAC
172
ThePapayaJaguar wrote:
09 Feb 2019, 00:24
M840TR wrote:
08 Feb 2019, 14:29
Another sneak peek
First through the air intake above drivers head.
Second I think is "fuel cap" position. Where they will sip fuel in
Redragon
19
Alonso might be testing today the MCL34 on the simulator as he is at MCL headquarters
M840TR
M840TR
315
Redragon wrote:
09 Feb 2019, 14:02
He's probably there for the Indycar but I wouldn't rule out sim testing the new car.
_cerber1
269
It is interesting to know his opinion.
ThePapayaJaguar
ThePapayaJaguar
F1NAC wrote:
09 Feb 2019, 11:16
09 Feb 2019, 00:24
M840TR wrote:
08 Feb 2019, 14:29
Another sneak peek
I was thinking it was the intake above the driver's head as well! If it is indeed an intake, I'm wondering how much bigger this one is in comparison to the MCL33's because its intake was considered to be a smaller one when comparing it to the competition.
M840TR
M840TR
315
A follow-up to the gold on the chassis debate, here it is being applied on the Mcl32's fuel tank region.
In entirety, it extends to the sidepod region as well.
The foil.
Another sneak peak
That seam's not straight. Ron Dennis wouldn't have stood for that, remake the chassis! :lol:
Morteza wrote:
11 Feb 2019, 18:21
Another sneak peak
https://pbs.twimg.com/media/DzIyOtTXQAEUOFu.jpg
somebody scan that QR code! :mrgreen:
desl
desl
37
Manoah2u wrote:
12 Feb 2019, 15:40
Morteza wrote:
11 Feb 2019, 18:21
Another sneak peak
It says: "34A-MO-00143311 / ZV464"
