Red Bull RB16B
OO7
OO7
171
Re: Red Bull RB16B
scheffers
scheffers
Re: Red Bull RB16B
:o
That is an impressive sight.
Re: Red Bull RB16B
Brightened it up a bit
michl420
michl420
Re: Red Bull RB16B
A wonderful rear end. They bring everything ( suspension, outlets, gearbox) up to give the diffusor more clean air.
OO7
OO7
171
Re: Red Bull RB16B
Morteza wrote:
13 Mar 2021, 19:45
https://i.ibb.co/jZsRZY8/348.jpg
Thank you, thank you very much.
DarthPlagueisTheVise
42
Re: Red Bull RB16B
Looks much much cleaner than the merc in terms of little aero pieces
Technical Noob
Re: Red Bull RB16B
Morteza wrote:
13 Mar 2021, 19:45
Very smart thinking by Adrian Newey as usual. The upper arms are so high. So much clean open space. They even had to make a large opening in the top knuckle because of its size. The lower arms are also high mounted to the gearbox but they left the connection point to the upright low. Probably for brake duct reasons.
Re: Red Bull RB16B
Morteza wrote:
13 Mar 2021, 19:45
Do you get the same WW1 bi-plane vibe from the wishbones that I'm seeing?
Sieper
73
Re: Red Bull RB16B
It does look very elegant. If that is fast I don’t know, but it does look it.
So, RBR has 8 of those little vortex creators on the middle (low) part of the diffuser, McL has just 4. McL has used a “trick” to make the two innermost vanes a bit lower to let them start from the inner piece. Reference plane is lower there. RBR has clearly chosen to accept the lower height and place them all 3 directly in the air stream. What would be better? Warrant a guess?
tmoneyr007
tmoneyr007
Re: Red Bull RB16B
Morteza wrote:
13 Mar 2021, 19:45
Dirty attempt at comparing McLaren to RBR
101FlyingDutchman
101FlyingDutchman
Re: Red Bull RB16B
Have to say that RBR16B rear is clean. Such nice and clear lines. Great work
SmOgER
SmOgER
Re: Red Bull RB16B
ferkan
ferkan
31
Re: Red Bull RB16B
101FlyingDutchman wrote:
13 Mar 2021, 22:42
Agreed. First time since 2017 that Merc does not look next level compared to main competitor. In fact, I am more impressed by RB.
Re: Red Bull RB16B
Compared to the 2019 rear-end (2021 AT02)
This very angled and aligned driveshaft+trackrod shrouded assembly is kinda reminiscent of another infamous Newey car, the FW.16, with its angled beam wing and its shrouded Y-shaped top wishbone+driveshaft ensemble
It's like a fusion of both things :P
https://lh3.googleusercontent.com/proxy ... G8nUh1EZPv
https://lh3.googleusercontent.com/proxy ... jZNmV4okhm
https://pbs.twimg.com/media/Dfvf_ROX4AAcDXt.jpg
Re: Red Bull RB16B
