Williams FW44
Mr Brooksy
Re: Williams FW44
This is the story that some if the above images came from courtesy of motorsport.com
https://www.motorsport.com/f1/news/what ... e/8599980/
WilliamsF1 fan since 1989
Moctecus
150
Re: Williams FW44
It seems there are still no top view images of the FW44, so I took some stills from their shakedown drone video.
Would be great if anyone had better quality top view images.
humble sabot
27
Re: Williams FW44
vorticism wrote:
01 Mar 2022, 23:29
..... If this front exit duct is open, less air travelling through the main sidepod inlet moves through the radiators and sidepods generally (assumption). So, in cooler weather, they open up this bypass duct and reduce stagnation in front of the main inlet. In hotter weather, they close it to force all inlet air through the radiators. If they can tune it this way they wouldn't need to manufacture multiple engine cover geometries for different weather conditions, only change the relatively small 'bypass' panels on either side.
Could be, but I think the idea that it's meant to control the flow over the top of the sidepod is probably a bigger part of its purpose.
I wasn't sure where I recognized the ridge shape on the side of the inlet from until I happened upon a shot of the Dassault Rafale while browsing for something else.
https://www.airliners.net/photo/France- ... /1726647/L
I think Kyle Engineers' theory that it was to induce a vortice is only kinda true, I think it's supposed to split the side flow from the top flow.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
tomazy
tomazy
218
Re: Williams FW44
Moctecus wrote:
03 Mar 2022, 09:06
I found this one, still not the best, but better:
Moctecus
150
Re: Williams FW44
Cooling gills
AeroDynamic
349
Re: Williams FW44
Moctecus
150
Re: Williams FW44
Testing a different bodywork/cooling configuration with the side pod hole closed and a gill panel with fewer slits fitted.
AeroDynamic
349
Re: Williams FW44
SmallSoldier
SmallSoldier
481
Re: Williams FW44
Williams running their floor really low on testing…
AeroDynamic
349
Re: Williams FW44
AeroDynamic
349
Re: Williams FW44
Re: Williams FW44
is that a liquid to liquid cooler?
A lion must kill its prey.
AeroDynamic
349
Re: Williams FW44
@Albert Fabrega twitter
maxxer
maxxer
Re: Williams FW44
AeroDynamic wrote:
11 Mar 2022, 11:14
https://pbs.twimg.com/media/FNjtO-vWQAA ... name=large
Finally see the underside of the new regs
Stu
Re: Williams FW44
11 Mar 2022, 11:05
It looks to fed by the duct immediately in front of it, probably an inter cooler rather than a charge cooler.
