nope can't see anything either.
just a flap from the front wing , a distant brake duct and some suspension components
Something is there... have a look at the super hi -resthestig84 wrote:Nothing under there. Have a look at other shots.ISLAMATRON wrote:not at all... there is something there under the nose, either a splitter or an elongated keelchristopher.mahlon wrote:
I think what you're seeing there is the upper element of the front wing.
As in, the grey painted underside of the nose cone?...ISLAMATRON wrote:Something is there... have a look at the super hi -res
http://www.gurneyflap.com/Resources/RED-1.jpg
Whatever it is that the front lower wishbone is connected toSaribro wrote:As in, the grey painted underside of the nose cone?...ISLAMATRON wrote:Something is there... have a look at the super hi -res
Underside of the nose, painted grey.ISLAMATRON wrote:does it not angle down like a keel? and what about the grey structure ahead of it?
The greyish bit is the bottom of the V shaped as a vertical splitter.ISLAMATRON wrote: Something is there... have a look at the super hi -res
Indeed!segedunum wrote:That's about the size of it. People are falling over themselves to talk about aerodynamics and how big their diffusers are when packaging and balance are going to be absolutely critical with 70 kilos of fuel wanting to move around under several G of force. Whoever can package that fuel efficiently, along with the engine and gearbox, in a finite amount of space and ensure that the components and aerodynamics around them are not compromised is gaining a big advantage in addition to the usual aerodynamic grip war. It's clear just by looking that Red Bull have compromised little, if any when compared to other teams on that front. The McLaren looks like a pregnant whale compared to the Red Bull and even to the Ferrari.RAF wrote:It would be rather funny if everyone else was concentrating on aero and diffusers and Newey was the only one actually putting all his efforts on packaging and balance.
That's one of the areas where Newey scores ahead of others. Only he would decide to come up with a pull-rod suspension system at the rear just so he can gain the knock-on effect of having the back-end packaged exactly the way he wants. Every component affects everything else.
