marcush. wrote:boys,I was talking about this months ago....
It is super simple... you need a cylinder with a piston incorporating a small bleed hole and a specified oil to achieve this effect...
Yes, you are right. This cylinder with a piston is the "second stage damper" in the figure above, and it should include the stiffness spring to recover the 3-4mm compressed once the car is stopped.
When I wrote "a traditional hydraulic fluid moving between two chambers
almost sealed." I was thinking in a small bleed hole between chambers.
Thanks.
autogyro wrote:Fit a flap over the bleed valve that only allows oil to bleed when the car is moving(and working the suspension) and you can time the ride level to go down from the 4mm gained from jacking (to take full fuel load), to finishing the race at the same ride height with nearly empty fuel.
I do not understand your idea. If the car is moving you have a big downforce over the suspensions and when the car is stopped this force is zero. IMO it is not necessary any flap over the bleed valve. The spring recover the height (3-4mm) when the downforce is not present any more.
The time constant of the second order system (the second stage damper with the piston and the stiffness spring) will determine the compression and the recovery time. They could be several minutes ... 30-40 minutes...
In other words, with a such simple system based on the addition of a piston with a bleed hole and a stiffness spring, the suspensions needs a "warm up" time.
