marekk wrote:I think (Warning, original research)
Take a tire on the rim. Cut top half of it, leaving bead on both sides intact. Find some way to seal both openings using something with good tensile strenght (you can use parts of this upper half - is useless anyway). Inflate. Put vertical load on it. Does the rim fall to the ground due to missing
TOP of the tire supporting the load?
Yes. The rim will pass through the bead, sliding into the tyre. The tyre would "open" toward the sides, unless you provide it with the "seal" inside the rim, holding together both walls, in red in the drawing I provided in the last page, when KSP made the very same question (actually, this "seal" would be the support for the wheel, as I tried to explain earlier).
There is almost nothing supporting this half tyre, as I see it, except the relatively small compression force the rubber can develop at the tiny horizontal surface between the bead and the rim, plus the friction between the bead and the tyre (also relatively small). Your tyre would go "puff".
The fact that you mention the "good tensile strenght" to hold the "flaps" sealing the wheel, can show you that those flaps cannot work! They also would go "puff" unless they are glued to the wheel.
Those flaps, btw, if glued perfectly to the wheel, would go in tension immediately. They would be the only thing holding the weight of the car (without the "seal" in red). I guess you can "see it in your mind" now.
Unless you convert your half wheel in the equivalent of this (with the red seal) there is no way to support the car! In white, the rim. In green, the tyre (but "sealed" as I tried to explain! Nice rim, btw.)
Red seal I mention (for those not reading previous pages in this thread)
Nice joke, btw ("original research"). Thanks for reading what I wrote.
Jersey Tom wrote:Meh, I gave up. Don't have time these days either. Started work at the race team this week. Busy busy.
Oh. I haven't read the whole thread, just the last two pages and I didn't notice you already have given the correct explanation, although I think that the drawings I made explain clearly the same thing for the unabated... I love structures and I was kind of incensed when I read that air support the car. Tyres are not like a balloon (although you COULD construct tyres that worked that way, they would be bumping funnily if they had no fabric or plies). They would have NO STRUCTURE.
Now I have read the first ten pages (well, skipped most posts, specially the ones estimating the increase in stiffness this season, but...). Thanks for all you wrote. Good luck with your season, Tom, break a leg. I also have to deliver tomorrow, but I'm so tired I needed to distract myself. Pretty interesting thread, anyway, I had no idea F1 wheels had walls with so little resistance to compression (the "wad up" mentioned by strad in... I don't know, post 1353 of this thread). Ánimo, Tom, what you wrote was very clear, I simply haven't read it when I declared everybody being wrong.
IN CONCLUSION: as JTom already said (I think) a tyre doesn't work like a balloon in compression.
It's an structure hanging from steel wires, wires that go inside the walls and in the bead, very similar (in principle) to a spoked wheel. As ringo explained (I think), is the air inside what prevents the top of the tyre from collapsing, providing the wires with the "towers" Dave mentioned. The bead (thanks, Tim) works as a girder in a bridge. Of course, that's an image that comes from a guy that makes roads. The tyre is NOT supported by the walls at its bottom, except in a very small part by their (tiny) resistance to compression.
This sounds counterintuitive, but, as I guy that has tried to work with membranes in structures, I can tell you that membranes are counterintuitive by nature...
For example: membranes at work. Question: will the smaller balloon inflate with the pressure of the large balloon when the valve sealing the tube that connect both balloons is opened? After all, the larger balloon has a larger pressure inside, ain't it?
Answer:
What gives?
