Curbstone
Curbstone
basti313 wrote:
02 Aug 2023, 13:15
marcel171281 wrote:
02 Aug 2023, 08:32
Given the (expected) wet weekend, wouldn't they have chosen a setup that would generate more heat into the tyres? And therefore they were very concerned about too much thermal deg. Something GP literally mentioned to Verstappen during the race.
I think this is the point. No one knew how the tires were affected, so they had to play it save in Eau rouge. If you run the car 1sec faster then the rest you simply have more risk of a tire failure.
That doesn't make much sense, which is also explained in the video. Eau Rouge / Raidillon might put some stress on the tire, but it's followed by a very long straight. This means the tire has a lot of time to cool, but also a small lift will give a speed deficit for a very long time. Resulting in the loss of about 0,5 seconds. Spa also has some other corners which are stressing the tires a lot, but which aren't followed by a long straigth. So lifting in those corners would relieve the tire just as much without the enormous time loss.
I listened to the onboard radio all race long, and I don't remember Max was told to do tire management in specific corners. I know that in other races this is a topic which is discussed clearly and without much code words.
The messages in Spa about the tires were mainly about 'bringing them in easily', and regarding the low tire temperatures in the end of the second stint.
I don't believe it was a tire issue.
bigjj
bigjj
Verstappen has always been able to perform well at home and proved that he is mentally strong
bigjj wrote:
02 Aug 2023, 14:04
Yes he has always been quick at Zandvoort. I suspect it's because he has a lot more experience than most at the circuit
The circuit also suits the characteristics of the car. The rb19 is excellent at managing tyres especially in hotter conditions and Zandvoort race will be all about thermal deg.
It's a smooth track which also will allow them to run the rb19 as low as they want.
02 Aug 2023, 14:18
bigjj wrote:
02 Aug 2023, 14:04
No, he hasn't. Why do you think that?
Farnborough
Farnborough
102
Curbstone wrote:
02 Aug 2023, 13:41
basti313 wrote:
02 Aug 2023, 13:15
marcel171281 wrote:
02 Aug 2023, 08:32
To offer a counter view, this section of the track isn't unduly affecting the tyre heat as primary concern, Pirelli say this is the absolute highest loaded experience the tyre sees in the whole calendar.
Lateral, traction positive, traction negative (braking) all heat the tread surface plus flex the carcass of the tyre based on surface adhesion and limited by that.
Vertical loading doesn't ultimately have the grip limitations, just how much the tyre is squashed into the ground. They make the tyre to handle the load total, with downforce etc by specific structure to control and restrain the CONSTANT vehicle load and duty cycle expected and so prevent failure in race conditions.
This section of track lays at the very far extreme of that reasonable performance envelope,, being careful here certainly makes sense if you dont really need the pace. CH words were to the effect that they could see the tyre "opening up" and usually an indication the tread temp is reaching or being held close to it's highest margin, ultimately this can lead to a reduction of the tyre capacity to handle the vertical loading it would normally be OK at, and particularly relevant to probably the most downforce effective chassis, may indeed move them closer to uncontrolled structural failure without much warning.
Looked entirely sensible to me. Can understand also the paranoia between drivers (we've heard this a few times already) hence the question about "the other car" :D that's just part of team management when success is on the table.
To me there's not much in way of conspiracy, no-one would want to chuck it away while holding 1 & 2 in reality, would they.
02 Aug 2023, 14:51
02 Aug 2023, 14:18
bigjj wrote:
02 Aug 2023, 14:04
He's demoed F1 cars there multiple times since 2016 prior to its addition to the calendar and has tracked GT cars there as well. Not to mention it's been a circuit available in various simracing for a long time (unlike many of the other new tracks such as Miami, Saudi etc)
02 Aug 2023, 14:57
02 Aug 2023, 14:51
02 Aug 2023, 14:18
Those were demonstrations with old democars and on demo tires and not at top speed.
In addition, the circuit has changed quite a bit a few years ago.
I don't think he was able to take advantage of that from those few visits to the circuit.
He set a lap record in 2016 there. So I'm not sure about "not at top speed"
And Max has been back to Zandvoort with race cars quite a few times since the layout was changed.
Respectfully disagree. There's a lot of time to be found in finding optimal lines through the banking and using that to save tyres etc, even more than a regular circuit.
For instance we saw when we first went in 2021 that max and Alonso were driving different lines to everyone else from the outset.
marcel171281
marcel171281
27
02 Aug 2023, 15:23
Nonsense. After the banking has been added to the circuit, Verstappen hasn't driven a meter more there than any other F1 driver. All his demo runs and F3 masters were on the old track with no banking.
Zandvoort has never been his home track. He has done countless more laps at Spa, Barcelona, and many, many more tracks.
Ah yes not a meter. Not saying he drives at Zandvoort more than other circuits. Obviously far from it.. but he has had more experience with Zandvoort than other drivers prior to its addition to the calendar and maybe that has helped. Maybe not.
Why is that so controversial :?
Look even if it hasn't helped it doesn't change that he's fast at Zandvoort, as he is at many other non-street circuits, and my point was that it bodes well for the weekend.
AMR are apparently bringing upgrades and the layout suits a car like Mercedes quite well.
Winning will be important with the 9 wins in a row possible after the summer break
02 Aug 2023, 15:23
Ahhh, so Alonso also has a lot more experience than most at the circuit too! Also in democars? :D
Tangentially related to the F1 team:
Max is setting up his own GT3 racing team, aiming for 2025
Interview with him
https://www.formule1.nl/nieuws/max-vers ... -raceteam/
Max isn't just focused on F1 at the minute and is driving better than ever. It is echoed of Hamilton's time at the top when he was often involved in many extra curriculars whilst winning championships.
The goal seems to be building a proper racing outfit and he's beginning already at the age of 25. What a legacy he could end up leaving on Motorsport
KimiRai
KimiRai
257
02 Aug 2023, 17:28
02 Aug 2023, 15:23
Alonso learned the different line in 2021 from a driver friend of his, forgot who he was.
02 Aug 2023, 17:33
Interview with him
Could there be conflict with Ford who have their own GT3 product?
A lion must kill its prey.
02 Aug 2023, 17:33
Interview with him
viewtopic.php?p=1152437#p1152437 :wink:
