2025 McLaren F1 Team
Re: 2025 McLaren F1 Team
CjC wrote:
23 Apr 2025, 23:28
No idea how informed this fella is but he’s suggesting that Mclaren are already running a post Spain compliant front wing….
Not sure if I’ve expressed the same opinion on here (I nearly did this afternoon) but I’ve been contemplating for a while if the Mclaren was close to or already compliant to the new test.
(Sorry about the ads)
And I absolutely agree with him that Mclaren will have a shocker in Spain which will send social media into meltdown exclaiming how the new tests have hampered Mclaren even though it has nothing to do with it
Interesting comment. In Jeddah I saw the Mclaren front wing several times during the weekend, and something stood out to me. I thought, "it seems like the Mclaren wing doesn't move as much anymore". I kept this to myself over the weekend because it was only a subjective take and Jeddah is a lower downforce circuit so the front wing would already tend to be trimmed which means there is less force pushing it back.
Could be something, could be nothing. That may explain a few things...Mclaren might be doing some A and B test during the free practice sessions which would explain a lot of things like the performance variation and the excessive flow viz usage just behind the front wing... :wtf:
If they have done it, then we might also being seeing the impact of the nerf.
Emag
Emag
110
24 Apr 2025, 21:26
To me, it seemed like their front wing was flexing less than last year in testing already, but I put a disclaimer on my post back then, not sure if it was due to the different angles :
Emag wrote:
27 Feb 2025, 00:24
https://i.imgur.com/INxZJbc.jpeg
It seems like there's less flex on the MCL39's front wing, but I can't be certain if it's due to the slightly different onboard angles or not. But even when looking at the onboard videos (not static images like these) of the MCL39, the flap movement doesn't seem as dramatic on the braking zone as it was with the MCL38.
In Jeddah, from front wing cams, it definitely didn't seem as dramatic as it used to be though, so it may be true that they have tuned it down in preparation for Spain. After all, it's not like FWs will be 100% rigid in Spain, they just wont be allowed to flex as much as they're (technically) allowed now.
Developer of F1InsightsHub
CjC
CjC
Literally guys I’m re-watching footage of Landos front wing in Jeddah and having a mild panic attack thinking the wing is moving a lot :lol:
However I don’t have any references to compare it to last season, tried looking on your picture @Emag but the adverts keep getting in the way, so I pied it off :lol:
All that is left for me to do is to consider how long are those metal ‘sliders’ on the top element- I can see that the wing flex the full length of them so are they 10 or 15mm long??
Just a fan's point of view
Seanspeed
Seanspeed
Back when Red Bull were being heavily targeted by clampdowns on front wing flexing(circa 2011-2013), they got by fine. And the FIA introduced those changes fairly rapidly, not like with Mclaren where they've essentially given them a free pass for the 2024 season, and then told them WELL in advance in 2025 that they'd be changing it later down the line. Mclaren are likely very comfortable with their situation, and also know their front wing flexing is not at all THE key factor in what makes their car so usable and fast everywhere.
I'd be shocked if it affects them negatively at all in terms of relative competitiveness, given other teams have likely been taking more crude measures to try and take advantage of this flexing. As always, it's the team that understands the rules the best that wins, not one that is fortunate with some singular loophole only they found advantage with.
CjC
CjC
24 Apr 2025, 21:26
CjC wrote:
23 Apr 2025, 23:28
So I’ve been contemplating this a bit further since posting the video.
I know there could be numerous explanations for the following but if we look at our ‘on track evidence’ in testing we saw Lando struggling with a loose back end and there was that video on social media of that guy saying that McLaren have so much front end they are going to be mega blah blah blah- which would suggest a front wing with a high flap angle to create a lot of downforce (a 15mm flexing front wing) fast forward to Jeddah- Lando puts it in the wall in Q3, afterwards Stella said that Lando missed the apex with understeer (the trait we would expect with a 10mm flexing wing) he runs wide on the exit kerb and the rest is history.
Or am I barking up the wrong wishful thinking tree?
CjC wrote:
24 Apr 2025, 22:57
24 Apr 2025, 21:26
CjC wrote:
23 Apr 2025, 23:28
It’s the first weekend in over a year that I ever saw a Mclaren understeer…but it could be other explanations.
Front wings aren’t why a car has too much front end anyway. It’s in the floor. Front wing is just fine tuning. You can’t take a car that doesn’t turn and just add front wing.
Emag
Emag
110
CjC wrote:
24 Apr 2025, 22:41
I am fairly certain the wing this year flexes less than last year, but it's not like the current one is winning any awards in rigidity. In any case, delving into arguments on who will be hurt the most by the Spain TD is just pure guesswork and speculative IMO. It all depends on how prepared teams are for it, but in any case I would expect RedBull to be impacted the less.
If you want to directly correlate loss from Spain TD with the amount of flex that each team's front wings currently exhibit, then in an order from least affected to most affected it would be like this :
1 - RedBull
2 - Ferrari
3 = 4 McLaren / Mercedes
But you never know how well each team is preparing for the TD and how impactful to the performance the flexing front wing is to each concept. Although it may be safe to assume that the biggest change will be seen on teams which currently exhibit the most amount of flexing, it is not correct to assume they're going to lose performance by the same degree their front wings will lose flexibility. Not too long to go to find out anyway.
NiyolHuayra
NiyolHuayra
With the news that Castore is out in 2026 and Puma in as official apparel supplier as per SportBuniess https://www.sportbusiness.com/news/excl ... t-mclaren/. I hope that the size of Puma and their supply chain will result in lowe prices for us.
mwillems
45
Emag wrote:
24 Apr 2025, 23:44
CjC wrote:
24 Apr 2025, 22:41
1 - RedBull
2 - Ferrari
There are no changes to the front wing since last year, that i can see.
Either there was a change last year or there hasn't been one. The wings require more than a bit of extra carbon stiffness so I don't think they could sneak a change in without it being noticed.
The last wing change was at Vegas and was designed to allow an extended front wing flap. This could be a pseudonym for wing strengthening.
-Bandit
Slahinki
Slahinki
NiyolHuayra wrote:
25 Apr 2025, 07:44
And better quality merch.
BMMR61
It will be interesting to see if the whole Horner-led outcry against flexing cheats will be a nothingburger. Of course McLaren has been at the brunt of accusations, because they've been smashing Red Bull and he hates Brown. It's just part of the Horner playbook, has been for years. He's a pretty effective character, even now when his golden days are running short. People have short memories and are easily manipulated to believe the almost unbelievable. Like that he actually believed Max was entitled to the corner at Jeddah and so they didn't tell him to give it back. Nothing to do with clean air. Incredibly manipulative.
CjC
CjC
BMMR61 wrote:
25 Apr 2025, 16:10
I personally believe the Horner show and tell with the pictures after the race in Jeddah was a facade to distract attention away from the numerous issues facing Red Bull at the minute for example how they are a one man team who are heavily reliant on Verstappen and the issues they have with wind tunnel correlation which the RB guys have hilariously called him out for because they reckon they don’t have correlation issues but are using the same wind tunnel… oops.
Anyway this isn’t for the Mclaren thread so :-#
CjC
CjC
mwillems wrote:
25 Apr 2025, 09:03
Emag wrote:
24 Apr 2025, 23:44
CjC wrote:
24 Apr 2025, 22:41
1 - RedBull
2 - Ferrari
Not that I’m as good at spotting the differences like I used to be but I thought they do have a new wing for 2025. I’ve seen a few comparisons on Instagram and the shape of the top elements are different however I’m not sure if the 2024 wing they used for the comparison was the same wing raced in Abu Dhabi.
There was no need for any of the teams to describe the changes to the car which have been made from end of 24 to the beginning of the 25 season in Australia with the car presentation submissions and also as you know if the front wing shape stays the same but they have reduced the amount of flex this too would not be needed to be disclosed during the season with said submissions.
CjC wrote:
25 Apr 2025, 18:25
Lando said Red Bull had the fastest car last time out (and several here say Red Bull is equally competitive all along) and Mclaren isn't dominant. Red Bull have seemingly managed to do that without Adrian Newey (Aston) and without Rob Marshall (Mclaren). So what issues are Red Bull actually facing to deflect from?
CjC
CjC
25 Apr 2025, 18:45
CjC wrote:
25 Apr 2025, 18:25
This
https://www.autosport.com/f1/news/horne ... /10713866/
