2025/2026 Hybrid Powerunit speculation
Zynerji
111
Re: 2025/2026 Hybrid Powerunit speculation
Tommy Cookers wrote:
11 Feb 2025, 14:08
Martin Keene wrote:
11 Feb 2025, 12:20
You'd need a supercharger or a completely different block architecture for a two stroke. A four stroke has a completely independent inlet stroke to draw in the inlet charge. A two stroke requires the use of the crankcase to force the charge from the bottom of the engine to the top for nat asp engines, or a mechanically driven supercharge to force the charge in against the exhaust plume.
'uniflow' (ie non crankcase-induction) 2 strokes have since the 1920s not (once started) needed a blower
(eg Petter 'Harmonic' and Crossley in the UK)
by having tuned-length exhaust systems .. and specially eg if they have eg an 8 speed transmission ....
yes a bit of induction air pressure (eg electrically-driven) is needed for starting
the hybrid F1 rules manage fueling and manage ICE load in a way helpful to the this ICE type
but the Zynergi-architecture engine won't have the sound he wants because the firing intervals will be so uneven
So, non-flat crank and no big-bang?
Not a 2stroke guy, but chain-sawing firewood recently seemed so simple and elegant with seemingly solvable drawbacks.
But just the current (modified) block with 2 stroke heads, probably hot V seemed like it could just be a simpler way to go. I haven't even gotten to the point of asking about using nitro-methane in them... Would 100L get a car to the end?? :wink:
648
Zynerji wrote:
11 Feb 2025, 18:57
....I haven't even gotten to the point of asking about using nitro-methane in them... Would 100L get a car to the end??
no
nitromethane is a very poor fuel compared to the conventional fuel
nitro has over twice the stoichiometric mass-specific energy ....
so makes over twice the power for a given air consumption ie from a given engine it gets over twice the power ....
but has about one eighth of the mass-specific energy so that power needs about eight times as much weight of nitro fuel
ie equal power might come from halving the engine size but would need 3 - 4 times as much weight of nitro fuel and ....
(nitromethane's own oxygen accessed by rich AFR) would allow an even smaller engine but need a disproportionate fuel load
such a semi-rocket piston engine might not last 5 races
Zynerji
111
12 Feb 2025, 15:15
Zynerji wrote:
11 Feb 2025, 18:57
no
As always, I love your responses!
Thank you!
taperoo2k
taperoo2k
Zynerji wrote:
10 Feb 2025, 19:56
Is anyone actually happy with the expected 2026 engines?
I'm of the mind currently that it could seriously just be best to move to a 1.6l v6 N/A-DI 2 stroke (v12 sound, and high RPM feel) with the current (mostly) block architecture and delete the turbo. Keeping a 240kw KERS to torque fill would seem preferable for economy and drivability. Then 2008 sized cars, and I'm in.
In an ideal world with synthetic fuels you'd go back to the V10 or V12 screamers. But that is of no interest to the manufacturers. F1 is a testing ground for Hybrid technology amongst other elements of the PU alongside being a marketing exercise.
What I see and hear for 2026 currently simply does not feel very impressive, and that is hugely disappoint to this long-time fan.
It's either going to be a clown car show in terms of the racing or it might actually be exciting. It's hard to say at this point. Max wasn't very impressed with the simulator runs with the RB PU a couple of years ago now. Things have likely moved on since then.
When you look at the technical challenges the manufacturers face for 2026, it is quite interesting. You have to wonder how much of an impact the synthetic fuels are going to have on the respective PU's performance levels.
DenBommer
DenBommer
Always great videos and analyses from Scarbs. And personally, it’s also nice to hear that I’m not the only one who sees it as a missed opportunity for F1 not to have regenerative braking on the front wheels—at the very least, to recover some energy.
mzso
mzso
65
I'm unclear how development will work, perhaps I wasn't paying attention.
They talk about submitting for homologation in a Honda article. So I guess the PUs will be instantly frozen? For how long?
Potentially another disaster in the making. As it was in 2014 where the development was limited by some point system. And even that they revoked seeing how things turned out. And even after it took other manufacturers to around 2020 to reach mercedes. (Not counting Ferrari's cheaty engines.)
mzso
mzso
65
DenBommer wrote:
06 Mar 2025, 16:58
Yeah, the cartel shouldn't have a say in the regulations.
ENGINE TUNER
ENGINE TUNER
25
mzso wrote:
08 Mar 2025, 13:26
You are incorrect, the token system worked very well. It stopped the manufacturers from making small revisions, and forced them to focus on both financial and performance efficiency. Ferrari made huge changes for 2015(and still didn't use all their tokens) and were almost up to par with Mercedes at that point, but I do think that is when they began fuel cheating. The token system allowed unlimited reliability changes yet Renault and Honda kept having problems well into 2018, so not a token problem. The token system did almost exactly what it was intended to do. Merc were just better than everyone else. The situation with engine parity was about the same as it was with the 2.4Lv8s, Merc and Ferrari the best. Renault and the rest struggling.
470
mzso wrote:
08 Mar 2025, 13:26
In Appendix C4, Table 1 there is a list of PU components with the upgrade schedule.
For instance, item 4 is: Main ICE assembly comprising Combustion chamber surface and pre-chamber detail within cylinder heads, piston, connecting rod, camshaft lobe profiles, intake and exhaust ports, Valvegear air spring sub-assemblies.
The homologation schedule for that item is 2026, 2027 and 2029. No new homologations for 2028 and 2030.
However, there is a category "Additional Development and Upgrade Opportunities". Manufacturers will apply for his if they are behind, and if they are granted this status they will be able to upgrade that component in years where upgrades are not available. Not all items allow that, though.
