Circuit of The Americas today announced that it has been declared ready to host the 2012 F1 United States GP by Charlie Whiting, who directs racing, safety and technical matters for the FIA. Whiting visited the Central Texas racing circuit as part of a scheduled pre-race inspection and approved the circuit for “Grade 1” status, hence appropriate to host an F1 race.
Would you rather watch a race car attempt to overtake another on a portion of track that promotes stability (the trough of a valley) or one that promotes instability (the crest of a hill)?
For what it's worth, the reason why Spa's famed uphill corner complex is known as Eau Rouge (the crest) instead of Raidillon (the dip) is because the crest is the hard part.
Have you tried driving Eau Rouge in the wrong direction (Raidillon down into Eau Rouge) in any racing sim?
bhallg2k wrote:For what it's worth, the reason why Spa's famed uphill corner complex is known as Eau Rouge (the crest) instead of Raidillon (the dip) is because the crest is the hard part.
Isn't a crest the top bit of a wave? That would make Raidillon a crest and Eau Rouge a trough. Eau Rouge is actually the dinky (when viewed in isolation) little left kink before the long uphill right.
I actually Googled for the correct terminology with regard to peak/crest/summit/ridge, etc., and valley/ravine/trough/gully, etc., but I wasn't patient enough to wade through the results. So, I just winged it.
As it's been explained to me and others who watch F1 on Speed, the dip/trough ("little left kink" area) is Raidillon and everything else, including the crest/peak/whatever, is Eau Rouge.
Either way, the moral of the story is that the Circuit of the Americas has, in my view, done precious few things correctly throughout their existence, and Turn 1 is one of those things. Video games run in reverse notwithstanding, I don't see anything at all that would indicate a downhill turn would be more potent than the reality of what's on offer.
Nope, I made the stability argument, and, as usual, I wasn't thorough.
The downhill instability to which you refer is, naturally, only possible if there's a hill in the first place. The cars here will go up the hill, turn left, and then immediately be going downhill. The destabilizing factors are all the result of the the hill.
If they were traveling downhill toward a corner at the bottom, the cars would tend to become stable at the apex and ever more stable upon the exit uphill.
bhallg2k wrote:Nope, I made the stability argument, and, as usual, I wasn't thorough.
So you are saying, turn 1 is BS, it just sets it up for a good turn 2
Banking would absolutely ruin this corner. What makes the corner difficult is the fact that it flattens in the middle of the braking zone and then turns downhill at the apex. It will be very hard to get just right, and if you get it wrong then your entire first sector is blown.
It's also one of the few first corners that Tilke hasn't ruined with a turn back.
Pup wrote:Banking would absolutely ruin this corner. What makes the corner difficult is the fact that it flattens in the middle of the braking zone and then turns downhill at the apex. It will be very hard to get just right, and if you get it wrong then your entire first sector is blown.
What would have made it good is, if it was not a hairpin
