I think it is useful to point out that the maximum torque may and will vary throughout the event, since it depends on several parameters which are not within the control of the driver or his team. Increasing ambient temperatures will cause a reduction of the maximum torque without it being a violation of the rules. The rules refer to the torque demand, which is not allowed to change for a given engine speed and accelerator pedal position.aussiegman wrote: What 5.5.3 does is prevent teams from using the ECU and mapping from arbitrarily altering either the torque delivery function OR the maximum engine torque for benefit.
If on examination a team’s ECU was found to have provided variable maximum torque at 100% throttle and maximum RPM during an event, then there is a clear violation of 5.5.3 in my opinion and as such it cannot simply be disregarded.
I guess that this boils right down to how you define "maximum engine torque". Is it the maximum torque you will obtain using a given engine map, or is it the maximum torque you would have obtained if you requested the theoretical maximum torque the engine is capable of deliver (at the measured engine speed).bhallg2k wrote:You have to consider torque demand differently than torque itself. Torque demand is the request, so to speak, and, similarly, torque is the answer. Apparently, the rules require a request for 100% of available torque from 5,000 RPM to 15,000 RPM. The "answer" may differ, but the "request" cannot change.*
Think of it as a woman: "Give me all you got. I don't care how much it is just as long as it's all of it." (EDIT: That's just my experience with women. Your mileage may vary.)
* There are exceptions within the regulations that deal with idle speeds, less than 5,000 RPM, and ignition base offsets from 15,000-18,000 RPM + 80-100% accelerator travel.
Code: Select all
Engine speed Theoretical engine torque Torque demand Actual torque
(rpm) (Nm) (Nm) (Nm)
12 000 365 350 350
13 000 370 350 350
14 000 375 350 350
15 000 360 350 350
16 000 345 350 345
17 000 325 350 325
18 000 310 350 310
As, they have not, It's fair to assume, that they are well aware of the fact, that this is not TC, and that they see no legalization to punish on grounds of illegal use of TC.9.3 Traction control :
No car may be equipped with a system or device which is capable of preventing the driven wheels from spinning under power or of compensating for excessive throttle torque demand by the driver.
Any device or system which notifies the driver of the onset of wheel spin is not permitted.
5.5.3 The maximum accelerator pedal travel position must correspond to an engine torque demand equal to or greater than the maximum engine torque at the measured engine speed.Stradivarius wrote:I guess that this boils right down to how you define "maximum engine torque". Is it the maximum torque you will obtain using a given engine map, or is it the maximum torque you would have obtained if you requested the theoretical maximum torque the engine is capable of deliver (at the measured engine speed).
Bauer was reluctantly overruled, I think is a better way to put it.Stradivarius wrote:If I have understood this matter correctly, what Red Bull have done, which caught the attention of Joe Bauer, is to lower the torque demand at certain engine speeds, so that they didn't exploit the engine's theoretical torque delivery at those engine speeds. Joe Bauer argued that since Red Bull's actual torque at those engine speeds where higher at Silverstone than their torque demand at those engine speeds where at Hockenheim, they were violating article 5.5.3. Joe Bauer was, however, overruled by the stewards who deemed Red Bull's engine map to be legal. Obviously, the stewards argued that the maximum engine torque could also be limited by the map itself, while the theoretical engine torque output is irrelevant. According to the reasoning of the stewards, the requirement to maximum accelerator position in article 5.5.3 is redundant.
Given the following...Stewards wrote:While the stewards do not accept all the arguments of the team, they however conclude that as the regulation is written, the map presented does not breach the text of Art 5.5.3 of the Formula 1 Technical Regulations and therefore decided to take no action.
...I think it's obvious we still don't have a full picture.McLaren's Jonathan Neale wrote:None of us really know what it is that antagonised the FIA so much to provoke Jo Bauer into issuing the note he did on Sunday morning. It was quite unusual step - I don't think the FIA would have referred to the stewards unless they had very serious concerns.
Because the design or type of performance 'legally' accomplished by RB is not what is desired by the rule makers or the FIA. They are changing the rules to 'hopefully' assure compliance with their objectives.bruceafc wrote:So if there having to make a change to the regs on the red bull surley that means there car must have be illegal to race at Germany, why is there a sudden need to change a regulation if nothing was found to be illegal on the red bull at the Germany Gp.
Not necessarily, I would say. If the Red Bull has tailored the torque demand at certain engine speeds to suit specific corners at a specific track, one could call it some kind of TC, but 9.3 wouldn't apply, since there wouldn't be any compensation for excessive throttle demand. For example, the team could observe that at a specific high speed corner, the driver can go flat out if they reduce the torque demand around 15k rpm. This would aid the driver in a way, because he wouldn't have to control the torque demand himself, he would just let the engine maping give him the optimal torque. This could be understood as a form of traction control, although it isn't the same as a system responding to wheel-spin.gato azul wrote:well, to but a different view, and perhaps an end to the TC debate, or we may spin it off into a "how does TC work, and what does it mean thread", because it has little relevance to this thread.
If the FIA would have thought, that it was TC, then they most likely would have claimed a breach of rule:As, they have not, It's fair to assume, that they are well aware of the fact, that this is not TC, and that they see no legalization to punish on grounds of illegal use of TC.9.3 Traction control :
Simple - no
I believe this sums up everything here quite nicely.Stradivarius wrote:[...]
I am actually not sure if this would be illegal, but I can understand if FIA don't want this to happen.
