turbof1 wrote:Sevach wrote:turbof1 wrote:I am still confused about the beam wing part. Piola obviously drew it, but I haven't seen any solid indication yet it will return. It might turn out to be an important device to improve overtaking.
With the upper wing lower and placed further backwards, wouldn't a beam wing interfere with it's airflow?
But that's exactly what you want. In the past the beam wing was important to link diffuser flow with rear wing flow. The resulting aero structure increased both rear wing and diffuser downforce through a bigger upwash.
My question is, with the endplate being diagonal from side view the main wing will be placed further back from where it used to be, the beam wing however will be roughly at the same placement it had in 2013 i'm assuming.
Wouldn't this dirty flow coming from the beam wing placed ahead of the rear wing (the wing is also lower) interfere with it on a negative way?
You might need a pretty neutral beam wing (if they are even allowed in the first place).
