#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
This one is from f1fanatic.co.uk, great quality!skoop wrote:Are there any shots of their new (now legal) rear wing?
But McLaren seems to have done a similar thing.everythingisawesome wrote:'Article 3.9.6 of F1's technical regulations states that the support must be extended until it meets the area of the regulations that is related to the area of the rear wing main plane as defined in article 3.9.1. 'aral wrote:The Renault rear wing support has been deemed as illegal and they have to alter if before Melbourne. Apparently it is too far forward and does not meet the mainplane as required.
It's a technicality - Renault bolted the pylon to the drs mechanism, which is then attached to the mainplane.
The regs imply that the pylon should attach directly to the mainplane, but are not specific - they found a loophole.
Does this make any difference? And if yes, what is the benefit of the original Renault solution.Thunders wrote:There is the now legal RW Pylon:
https://imgr2.auto-motor-und-sport.de/N ... 042649.jpg
I mean, swan neck wing mounts are known to be more efficient for a good reason - thy don't interupt the flow of air underneath the wing at the wing mounts.matt21 wrote:Does this make any difference? And if yes, what is the benefit of the original Renault solution.Thunders wrote:There is the now legal RW Pylon:
For me it doesn´t really matter, and as a designer I wouldn´t put too much of effort there.
