McLaren MCL33
Redragon
19
Re: McLaren MCL33
cyclon wrote:
27 Feb 2018, 14:07
A bit scary .....
but if you check where pit crew blowing air it's easily understandable that they know about it!
That's why the small inlets...
and it is freezing cold
cyclon
-2
Re: McLaren MCL33
Redragon wrote:
27 Feb 2018, 15:29
cyclon wrote:
27 Feb 2018, 14:07
A bit scary .....
Ok but take in account that density of air is also lower when freezing cold ..
A lot of parameters to take in account!
I loved the iconic McLaren-Honda
But most of all i love McLaren . After all first contact made with M23 that had a Ford Cosworth PU
Re: McLaren MCL33
Redragon wrote:
27 Feb 2018, 15:29
cyclon wrote:
27 Feb 2018, 14:07
A bit scary .....
Inlets or outlets ?? Bit difficult for sufficient air to go in there ??
BrunoH
BrunoH
Re: McLaren MCL33
if its buring now, it will burn more if it gets hotter outside... maybe a little 2 tight on that area and the engine cover touching something very hot..!?
cyclon
-2
Re: McLaren MCL33
BrunoH wrote:
27 Feb 2018, 15:39
I hope so ...
But if you look at these
https://pbs.twimg.com/media/DXCzzQ9XcAAvlbY.jpg
https://pbs.twimg.com/media/DXCzzIgX4AAlYD_.jpg
It looks like they are checking the area right now!
cyclon
-2
Re: McLaren MCL33
mclaren111 wrote:
27 Feb 2018, 15:33
Redragon wrote:
27 Feb 2018, 15:29
cyclon wrote:
27 Feb 2018, 14:07
A bit scary .....
You are right they are so small! Almost working in a fluidic type of air...
the EDGE
the EDGE
67
Re: McLaren MCL33
BrunoH wrote:
27 Feb 2018, 15:57
you need the testing thread forum/viewtopic.php?f=1&t=27067
this is the thread to discuss elements of the car. no team/testing/livery or panic talk allowed in here
Edit Thunder: deleted OT, kept good advice :D *easymodeon*
proteus
22
Re: McLaren MCL33
Redragon wrote:
27 Feb 2018, 15:29
cyclon wrote:
27 Feb 2018, 14:07
A bit scary .....
It well might be a cracked heat shield. Engine generates fuming exhausts, while the exterior air is freezing cold, such violent expanding and contracting can make damage.
rccrdc
rccrdc
Re: McLaren MCL33
Re: McLaren MCL33
ScrewCaptain27
577
Re: McLaren MCL33
Via AMuS
- Serj Tankian
Maritimer
Maritimer
19
Re: McLaren MCL33
cyclon wrote:
27 Feb 2018, 15:32
Redragon wrote:
27 Feb 2018, 15:29
cyclon wrote:
27 Feb 2018, 14:07
A bit scary .....
Air density increases as temperature decreases
Giblet
Giblet
Re: McLaren MCL33
DiogoBrand wrote:
26 Feb 2018, 16:47
They already showed it last year. I don't see why it would be a 'last minute part'.
The Halo last year was not the finished product, and IIRC it was a single element last time we saw it.
Re: McLaren MCL33
Is there perhaps a photo of front wing under side? Or at least a photo of it from the back?
aral
aral
26
Re: McLaren MCL33
Children, children....can you not see that this thread is a technical thread about the MCL 33? Talking about McLaren honda, or STR honda is of no relevance.
