Francesc wrote:
This is the same as the Mac gearbox.
Note a few interesting things:
The case has open sides, you can see that some airflow passes from the sides up into the centre. they have some cable passign through this gap.
The antiroll bar sits on top of the case, the pull rods are obviously low down and no dampers or stuff are on the sides of the case. Not visible here, but I know the torsion bars are vertical. I still cant work out how the pull rod rocker operates on the dampers\heave spring and ARB.
That missing rear section is probably the fairign that joins the lower crash structure to the diffusers central gurney.
