Mercedes AMG F1 W05
SiLo
138
Re: Mercedes AMG F1 W05
Hamilton was quoted as saying that after he lost 50-60 points of downforce from destroying the cars floor, he couldn't even take eau rouge flat, as if it was simply a formality that they were flat through there.
Felipe Baby!
flyboy2160
flyboy2160
84
The Team or Race threads are the place for discussing speeds, lap times, and driver preferences, not the car threads.
Video new nose W05
Crucial_Xtreme
Crucial_Xtreme
404
GA on Merc's monkey seat
via AutoSport
lio007
316
Here is a pic of Merc's splitter with removed covers:
Does anybody know what this thing could be for?
Owen.C93
Owen.C93
177
http://www.racecar-engineering.com/wp-c ... mercc5.jpg
Probably just some form leaf spring that deforms backwards as the splitter changes it's angle upwards which will then allow for much more flex so they can run the car lower without destroying the plank. It's setup that way so it can pass the specified FIA deflection mm/kg test and then after that it will yield.
Excuse the crude online paint drawing done using a trackpad, but I think you get the idea
Standard
Fia test, lots of force, small deflection
Exceeding that force by a small amount but lots of deflection as the material snaps backwards.
Easily tunable by changing the length, angles, and thickness.
Italy 2014 - Thursday (04.09.2014)
Rear wing wavy on the lower edge too now :lol:
Juzh
161
That's a lot of wing for monza. Looks like they're taking a similar approach as in spa. Gonna be a murder-fest if there's even hint of rain on the track.
krisfx
krisfx
deterherligt wrote:
mf_fer wrote:First post here, recently registered but I do have been reading some threads here for a while, having justified myself for any newby mistake here's my question.
Today, as Nico locked his left front wheel which gave him some "on the limit" vibrations after due to the flat spot(s) the lock wasn't just a case of a locked wheel dragging and then releasing, it happened at least 3 times in that short amount of time. That reminded me of the operating principles of abs in cars.
Know, I know an F1 one driver is well capable of managing his brakes, but it also occurred to me if the portion of braking provided by the energy recovery system could be electronically tuned to reproduce such effect and therefore minimize or distribute a huge flat spot on the tire over smaller ones.
F1 drivers pump the brake to imitate abs IIRC
They will pump the brakes when the wheels lock, but until that point they pretty much go hard on the brakes and slowly release pressure through the braking phase I think.
lio007
316
New RB'ish slot in front of the rear tyres:
https://twitter.com/ScarbsF1/status/507528162444857345
Ninners
Ninners
Wing comparison to Spa.
Other comparison R WING MERCEDES SPA MONZA
mrluke
mrluke
The length of end plate visible above the start of the wing has almost halved :shock:
