Mercedes AMG F1 W03
MIKEY_!
Re: Mercedes AMG F1 W03
Artur Craft wrote:
JohnsonsEvilTwin wrote:
Also remarkable that Mercedes do not have the de rigour rear tail skirts as found on Most front running teams cars.
can you describe it? I'm a layman, I never heard of this rear tail "skirts" before?
I think we are talking about those black fins on the bottom of the endplate.
zyphro
zyphro
marcush. wrote:True to it Mercedes have not changed their approach to build the "Other "car and not copy the RedBull or Mclaren.
Is it they are slow in reaction or do they only adopt things they understand and have proof of working ..
I think they will have looked at what others are doing. But of course, you can only put it on the car if it won't negate the performance.
hardingfv32
hardingfv32
In general how does the brake cooling flow exhaust from the hub assembly?
Brian
Image[/quote]
Gridlock
30
Crucial_Xtreme
Crucial_Xtreme
404
I think we can see part of the DDRS duct in these pictures.
Not this one
Crucial_Xtreme
Crucial_Xtreme
404
Even better shots
Gridlock
30
Interesting the exposed pipe seems the same diameter as the rear pipes around the side of the engine I posted earlier, another sign the system isn't switched in my opinion.
I still believe that the fact there are 2 individual airflows going from rear to the front (I presume with no left-right crossover) is either packaging requirements or more interestingly the system actually works like this, i.e. different stalling speeds on each side of the car to aid yaw or traction etc.
#58
AnthonyG
38
I doubt the slot is really a slot, but what would be the use for the small extra hole?
Small vertical fin, lines up with the barge boards I think
Ferraripilot
21
The monkey seat will be there at Monaco.
zyphro
zyphro
Ferraripilot wrote:The monkey seat will be there at Monaco.
How do you know?
Crucial_Xtreme
Crucial_Xtreme
404
How do you know?
Because there's a 99.9999% chance every team will use one. Teams need the extra downforce at Monaco. Before this season with all the lost downforce due to the Regs, the Monkey Seat was almost exclusive to Monaco.
zyphro
zyphro
Crucial_Xtreme wrote:
How do you know?
Oh right.
wrcsti
wrcsti
id be damned if they dont run a bmwf109 style extra wing on the DRC activator for monaco.
hardingfv32
hardingfv32
I would say that what you think is a slot is just the remnant of a fillet layer where the wing strut bonds to the nose.
Brian
Mandrake
Mandrake
AnthonyG wrote:I doubt the slot is really a slot, but what would be the use for the small extra hole?
Great picture! You can see two pipes in there, the big diameter hole which seems to be the one running from back to the front and then at the very front end of where the pylon was there is a smaller tube from what I think is fed by the nose hole.
