autogyro wrote:Looks like a torturous route for the exhaust manifold to join the turbine housing.
If it is like that in the car, it will be a devils own job to prevent heat loss from the manifolds.
Whats the big box on the top, heat exchanger for charge cooling?
I would have expected the charge cooler to be in the side pods and to be much bigger.
If the unit between the compressor and turbine is the MG, that might have a cooling issue as well.
I think they also put water cooling in that MG, otherwise, it won't last a single lap.
The big box on the top is a mistery, also the air intake trough the middle of the engine, underneath the airbox/cooler.
The box just won't fit in an f1 car. so it's just there to cover something.
My guess, air intake just behind, or beside the driver(trough the side pods) and the air to the intercooler in the conventional airbox. Because an intercooler needs a lot of air at 2/3 bar.
