McLaren MP4-27 Mercedes (pre-launch speculation)
aleks_ader
90
Re: McLaren MP4-27 Mercedes
beelsebob wrote:
ell66 wrote:Id put money on the sidepods looking prety similar to this year, theyv even hinted as such. Be intresting to see what they do with the gearbox and rear end though.
Agreed – as far as I can see the packaging at the rear is the biggest problem on the -26. We know they can lower the gearbox down a chunk after last year's exhaust fad, and I suspect that the packaging could be yet tighter than they managed to get it this year.
And that rear compactness could be crutial for next season! Beacuse with lower rear section they will gain on downforce level from diffuozor, but on the same time they will almost keep almost the same level of low drag penatly! They must somehow equalise the of EBD downforce lost...
But there is problem in exhaust monting point? Maybe will be the most usefull if they squizze closer to the engine and try blow toward under rear wing?
230
There is a limit to how tight the sidepod can get. The heat has to be rejected from radiators, kers, exhuast etc. With the U pod, volume is at a premium.
The only solution to tightening is to not tighten, but to move the wheels further away from the side pod. This translates to an increase in wheel base.
I would go with as long a car as possible. It only need to be able to make the tightest corner on the calender.
Exhuast positioning is also critical with the U pod. It can in fact cause the car to lift if mclaren aren't careful. Dont want to much acceleration of air over the side pod. That is not good. They only need enough to prevent separation.
You want the air over the side pod to decelerate. From the sides you want sufficient speed over the beam wing. Therefore exhuast may be angled slightly inward.
I think 2012 will see highly under developed cars at the beginning. The teams will only converge on a good idea when they see one team running away with wins with a particular side pod shape.
Not many areas left on the car to blind side another team with. All innovations will be copyable.
aleks_ader
90
ringo wrote:There is a limit to how tight the sidepod can get. The heat has to be rejected from radiators, kers, exhuast etc. With the U pod, volume is at a premium.
Sure that is the maine problem and space around it...
Yes it true, but i actually preffer to adapt on the most of rest races wihout Monaco, which is to specific race... I think the longer whellbase like Red Bulls will be slighty to occurred...
Yes that is the main problem how to mount the legal exhaust exit on u pods design.. And i mentioned in previsious post that the exhaus most be highest and toward the rear and as posibble...
Hmm but wait to the "end of beggining" is not good idea! Remember the many others seasons where other teams very struggle to catch up the leader team!
Banki
Banki
Maybe somebody has already asked this. What do you think that some engineer left the McLaren to join the Ferrari or Torro Rosso. Will they be weaker? or have they got younger, more talented men for this positions?
raymondu999
Everyone is always leaving Team A for Team B. it's not much special in the paddock. Some guys switch back and forth between teams too. Tombazis and Iley spring to mind. Theyve "pingpong'ed" between McLaren and Ferrari for quite a while, though Iley's jumped out of the loop now
失败者找理由,成功者找方法
Gerhard Berger
Gerhard Berger
-1
raymondu999 wrote:Everyone is always leaving Team A for Team B. it's not much special in the paddock. Some guys switch back and forth between teams too. Tombazis and Iley spring to mind. Theyve "pingpong'ed" between McLaren and Ferrari for quite a while, though Iley's jumped out of the loop now
Yes this is true. I've read the turnover between Mclaren and Ferrari is particularly high, which I guess is quite surprising given that they are such big rivals and located in different countries.
beelsebob
beelsebob
85
It's not that surprising when you frame it as "given that they have been established as one of the top 3ish teams for the past 50 years"
Banki
Banki
Thank you for your answers. It's very interesting indeed.
In other sports, football for example, it would be sacrilege
ianwit
ianwit
Re: McLaren MP4-27 Mercedes (pre-launch speculation)
Anyone else noticed that Scarbs tweeted a french report that the 27 already has surpassed the downforce levels of the 26? Is this a surprise or expected?
Became a McLaren fan in the late 70's when I ended up laminating their Kevlar nosecones.
ajdavison2
ajdavison2
30
Teams say that every year, just PR speak in my opinion.
wunderkind
wunderkind
ianwit wrote:Anyone else noticed that Scarbs tweeted a french report that the 27 already has surpassed the downforce levels of the 26? Is this a surprise or expected?
That's promising stuff. I hope they will start the season with similar levels of downforce to that of Red Bull.
Regarding the few staff decamped for Ferrari. Did they have anything to do with the 27 or they have had very little to do with it? Some reported a number of them left McLaren some months ago. Let's hope their departure will have no negative impact on McLaren's performance this year.
FrukostScones
162
twitter:
@franconugnes franco nugnes
La McLaren Mp4-27 accorcia il passo per salvaguardare le gomme anteriori e ha già ritrovato il carico aerodinamico del 2011
http://www.omnicorse.it/magazine/14431/ ... corso-anno
shorter wheelbase to protect front tyres... (did the rear tyre dimensions change?)
astracrazy
astracrazy
31
they will always say its better because we don't know the value of this.
Lewis will say during testing its the best car his ever driven as well. Happens every year. Last year he said it was better than the mp4-25 yet we know that that's not true because of the exhaust issues.
Its PR and to please the sponsors (as DC said in the BBC preview show last year)
I believe its better or as good when i see the times
ledzep4pm
twitter:
Assuming google translate is right then apparently "The team also are working on an innovative solution that will not go on the machine from the first Grand Prix". Is this just another way of saying regular updates in PR speak or have they got something special to bring at the start of the season (when it will b harder to copy) like the f-duct !
Also
Twitter @ledzep4pm
raymondu999
astracrazy wrote:Lewis will say during testing its the best car his ever driven as well. Happens every year. Last year he said it was better than the mp4-25 yet we know that that's not true because of the exhaust issues.
Said it of the MP4-24 too.
Frukost- the rear was made stronger to soften the loss of the EBD IIRC
失败者找理由,成功者找方法
