[KVRC ~ish] CCE LMP01
LVDH
46
Re: [KVRC ~ish] CCE LMP01
BTW I tried the front pod diffuser on my car, just for the sake of it.
I had problems with convergence and I do not use the KVRC tool.
I suspect that there are transient effects that cannot be captured with the steady state approach. And as steady state is the way to go for this competition I do not recommend using this kind of device.
It does not seem to benefit the performance anyways.
CAEdevice
50
LVDH wrote:BTW I tried the front pod diffuser on my car, just for the sake of it.
What do you mean with "front pod diffuser"?
LVDH wrote:I suspect that there are transient effects that cannot be captured with the steady state approach.
I confirm your impression.
RicME85
52
Like my car has/had
machin
162
Top left image shows "with front pod diffuser", bottom left shows "without front-pod diffuser".
CAEdevice
50
RicME85 wrote:Like my car has/had
machin wrote:Top left image shows "with front pod diffuser", bottom left shows "without front-pod diffuser".
Thanks for the explanation. I tried something similar before the first race, but I could not make it working.
LVDH
46
CAEdevice wrote: What do you mean with "front pod diffuser"?
So you trust what I say, although you do not know what I am talking about?
I like you.
CAEdevice
50
I like you.
I didn't know what you meant with "front pod diffuser" but I had the opportunity to test the limit of a steady state solution in other areas. Not a matter of trust.
variante
138
Yeah, i saw that too, yesterday :o
I will test it against my current wings. I expect my wings to have greater downforce but far less efficiency. Let's see what actually comes out...
RicME85
52
I have been following the feed in the hope of something like that :D
Very interesting to see the actual shape of the airfoil from an F1 car.
andylaurence
123
I've a selection of wing profiles from the Marussia archive. I currently have a 2013 beam wing and 2014 upper element in progress to put on the Egoboost.
LVDH
46
I would be interested in a beam wing. Mine is really bad.
andylaurence
123
I can't find the picture of a beam wing right now. Here's a monkey wing and crash structure instead.
variante
138
Awesome!
Anything you have about wings would be of great help. Especially about the front wing assebly and the way airfoils are matched.
