While you keep discussing about that straw man Bhall put in front of you (nobody said a word about removing the FW or banning those airflow deflections wich reduce tire drag, and I did even said it before the discussion with rsja began), I´ll try to keep on topic, posting some
unanswered questions wich, contrary to this late discussion, are related to the thread
Andres125sx wrote:bhall II wrote:Andres125sx wrote:Not on the fly, and that´s exactly the intention.
That's neither true nor relevant.
What?
It is true, you cannot change DF on the fly with traditional wings, at least that´s what you´ve been stating from the beginning. And you can with a fan as it is as simple as changing fan speed or blades pitch. Also, is relevant as that´s the problem about dirty air, drop in DF, so not sure what do you mean with this, it is true and relevant.
Andres125sx wrote:Airfoils make no magic, they can create a lot of DF/lift with a lot of drag, or minimize both, but you cannot create a lot of DF with very little drag. If you can patent it and you´ll be millionaire in no time.
But with a fan car you can, look at the drawing you posted on previous page, no need for any high cambered wing wich in reality is very similar to an airbrake (lots of drag), so if drag is reduced because you don´t need high cambered wings, dirty air is reduced, and the problem is reduced.
That´s posible with a fan, but not with a traditional wing, so please explain to me how that wing can be more resistant to dirty air than a fan when:
1- Any high cambered wing causes a lot more dirty air than a fan wich can be installed on a slippery (low drag) car
2- Any wing is more sensible to dirty air than a fan
So a fan is a less sensible device to dirty air than a wing, and it also reduces dirty air, two reasons in favour of a fan when compared to a wing, so please elaborate what you mean when stating a simple and giant wing is less sensible to dirty air. If you´re only comparing with current wings I´d agree, but not if you compare it with a fan.
Sorry to say this Bhall, but checking the thread it looks like you enjoy derailing the discussion, specially if we reach a point where you cannot find any reason to dislike the idea. Maybe I´m wrong, sorry if that´s the case, but that´s my feeling when I check the thread and see how many critical questions didn´t find a reply and at the same time how much time you invested talking about aspects wich are not related and nobody talked about...
When I look at the "Straw man" definition, many of your posts match it perfectly, specially the last ones talking about tire drag, steering angles and some other irrelevant (to the discussion) aspects. They´re very interesting and if a moderator split that discussion into a new thread I´ll follow it too, but they are not related to this thread and only make this thread more confusing
