Force India VJM10 Mercedes
ClarkBT11
Re: Force India VJM10 Mercedes
Austrian GP Wednesday via AMUS
Looks like Force India have brought two different wings to Austria.
Makes sense, probably evaluating where they make up more time, sector 1 or 3.
ClarkBT11
godlameroso wrote:
05 Jul 2017, 22:28
Would the bottom wing be less sensitive behind traffic given the bigger and less split wing sections?
It would be more sensitive if anything, given similar setup.
ClarkBT11
PhillipM wrote:
05 Jul 2017, 23:06
On Ferrari's​ 1st front wing 1st element was deep then got split into two elements. I read the split would have given better overall downforce but more sensitive to dirty air. Could you explain why it's wrong?
Cheers
Fewer and larger elements are more sensitive because they depend on laminar flow over a greater surface area. Smaller but more numerous elements are less sensitive because each element requires less laminar flow per area to affect the surface.
That's why birds have many small feathers with further divisions instead of just a few large fixed ones.
If you want to learn about aerodynamics, you have to consult the best of the best, no one has more experience with flight than someone that was built by nature to do it. Either that or a real bird brain, hell I wouldn't be surprised if Newey has a falcon or two. :P
ClarkBT11
Thanks, l should know better than to listen to Gary Anderson. They make you pay to read that to. :lol:
Sushant008
Sushant008
Some new fins-
Airflow sensor on the floor-
Front and rear tire temperature cameras-
Front wing details-
Some more pics-
All thanks to ScarbsTech and AlbertFabrega twitter feed.
ScrewCaptain27
577
Underside of the nose and FW (AMuS):
- Serj Tankian
Sushant008
Sushant008
Force India to bring biggest update of the season to Silverstone.
https://www.motorsport.com/f1/news/forc ... ne-929019/
trinidefender
trinidefender
318
godlameroso wrote:
06 Jul 2017, 00:11
No, just no. Most wings, especially those in F1 are not subject to laminar flow at all.
Wing elements stalling is a result of a decreasing pressure gradient that is too high. Wings with smaller but more numerous elements at the same AoA will stall later because the slots allow airflow to move to the low pressure side of the wing. This reduces the pressure gradient.
Do some more research on laminar flow.
trinidefender wrote:
12 Jul 2017, 20:53
godlameroso wrote:
06 Jul 2017, 00:11
I guess they work in a vacuum.
Furthemore numerous elements shed vortecies which straighten out subsequent flows, which indeed makes the macro wing less sensitive.
trinidefender
trinidefender
318
godlameroso wrote:
12 Jul 2017, 23:00
12 Jul 2017, 20:53
godlameroso wrote:
06 Jul 2017, 00:11
A vacuum? What are you talking about?
Most wings use in aviation do not have laminar flow aver the whole chord of the wing. Dirt, rough paint, bugs and pretty much every other imperfection is enough to trip the flow. So much so that people have the misconception that the P-51 mustang wings had complete laminar flow. While that was a design goal, it was discovered that, with the wings being new and clean, the designers achieved laminar flow over approximately 40-50% of the chord of the wing (can't remember the exact numbers from the study and can't be bothered to find it). The rest of the flow is turbulent.
No multiple element wing has anything close to laminar flow on anything other than the first part of the chord of the first element.
You're right, and I'm sorry because I can't take it back. I meant to say boundary layer, I apologize.
