Mercedes-AMG F1 W10 EQ Power+
f1316
f1316
82
Re: Mercedes-AMG F1 W10 EQ Power+
mantikos wrote:
18 Feb 2019, 16:32
The floor area is massive and the side pods miniscule
I was thinking that too - I think it’s the most impressively small in terms of sheer width.
ScrewCaptain27
577
Bargeboard flow-viz:
AMuS
- Serj Tankian
ENGINE TUNER
ENGINE TUNER
25
f1316 wrote:
18 Feb 2019, 23:28
mantikos wrote:
18 Feb 2019, 16:32
That is a direct function of the long wheelbase. All the cars are about the same length from the front axle centerline to the front face(and even back face) of the engine. The major variation in length is between the back face of the engine and the rear axle centerline.
230
The car no longer has the horizontal horns in the barge board area carried over from w09, but has replaced the horn with three airfoil elements that if you look from the top view, would fulfill the function of the horns from last year by having roughly the same plan area and within the same footprint. Very smart development by Mercedes.
Most teams like mclaren are copying last years horns, merc have moved the needle further.
Third year in a row Mercedes are doing things 50% different in barge board area. Two very thick surfaces around side pod inlet driving flow down, not a small amount of drag.
Via AMuS
Also I forgot to post this here (already in the comparison thread)
Fins on the brake ducts
Via @NicolasF1i
Helios
Giando
93
Then I was actually WRONG.
The push-rod is connected as 'usual'.
I don't know, nevertheless, what were those bulges clearly seen in the first Silverstone laps...
dren
226
Giando wrote:
19 Feb 2019, 12:40
http://i63.tinypic.com/6sdpgw.jpg
I thought the same thing, must have been an illusion. Those fins inside the rim are similar to the Mclaren fins.
Honda!
GPR-A
37
dren wrote:
19 Feb 2019, 13:54
Giando wrote:
19 Feb 2019, 12:40
I don't think that was illusion. It was very clear in the earlier pictures. Might be that, Mercedes is testing different bits.
santos
santos
GPR -A wrote:
19 Feb 2019, 14:10
dren wrote:
19 Feb 2019, 13:54
Giando wrote:
19 Feb 2019, 12:40
I was looking to the pictures in Silverstone and i don't see any difference. What bulges are you guys talking?
ScrewCaptain27
577
santos wrote:
GPR -A wrote:
19 Feb 2019, 14:10
dren wrote:
19 Feb 2019, 13:54
At the launch there was this bulge on both pushrods. Some thought it was a cover for some sort of pivot but it looks more to me like a kind of sensor/camera housing or just a diversion tactic.
- Serj Tankian
