McLaren MCL36
Re: McLaren MCL36
GTO99 wrote:
13 Feb 2022, 02:04
mcjamweasel wrote:
12 Feb 2022, 01:45
https://pbs.twimg.com/media/FLWn_ibXsAA ... ame=medium
Surely I can't be the only one to see it?
What is the advantage of this wheel design vs the old spoked style?
BBS is making tons of money in 2022... :lol: :lol:
BestOfDiResta
BestOfDiResta
Re: McLaren MCL36
Suspension will likely be as stiff as possible to allow the cars to run as low as possible given they’re ground effect cars.
Tombola37
Tombola37
Re: McLaren MCL36
Hi there new to this board. No aero expertise but an F1 fan for years.
That area of the nose which looks sculpted into the wing I believe is another carbon cover no? There is an edge on the right which isn’t bonded properly to the wing. I think MC are hiding the true wing/nose structure.
Marc.W
26
Re: McLaren MCL36
Tombola37 wrote:
13 Feb 2022, 11:34
It's definitely not as pretty as the Aston Martin solution, but I don't think anything is being hidden behind this, just a little bit of carbon for a smoother transition in the wing
wowgr8
wowgr8
29
Re: McLaren MCL36
Macklaren wrote:
13 Feb 2022, 02:12
Everything I have read in the last 48 hours indicates the opposite. These cars are going to handle like go-karts and be incredibly stiff with no ability to ride the kerbs. Daniel has been talking about the cars giving drivers headaches.
I wonder if that plays into Newey's hands given his history of making extremely stiff cars for Mclaren and Red Bull
Ricciardo said he hopes that the cars aren't that bad, he didn't say that they are
Re: McLaren MCL36
They're going to be stiffer, the aero platform is more sensitive and they've taken away a lot of the tools that allowed them to run softer with hydraulic/interlink effects to stabilise the platform.
dandfx
dandfx
Re: McLaren MCL36
Found on Reddit
Fer.Fan
Fer.Fan
Re: McLaren MCL36
dandfx wrote:
13 Feb 2022, 13:25
Found on Reddit
https://i.ibb.co/qsJyvSQ/RDT-20220213-2 ... 406549.jpg
HUGE heat outlets, compare that with Aston och Haas. Mclaren is a basic 2021 concept car. I wonder if their aero concept is right one. Lets hope so…
MrGapes
Re: McLaren MCL36
Fer.Fan wrote:
13 Feb 2022, 13:56
dandfx wrote:
13 Feb 2022, 13:25
Found on Reddit
It’s far from basic, it’s a alternative packaging solution, and that alternative approach consist of this larger rear outlet. All three cars we’ve have seen so far would have pretty similar volumes, just distributed differently. And all three will require compromises, the Aston requires cooling vents along the body surface in exchange for a tighter rear and undercut, while the haas (which is a early developmental render) has beefier side-pods and may still have gills.
Zynerji
110
Re: McLaren MCL36
PhillipM wrote:
13 Feb 2022, 13:14
I feel that this will lead to most close duels on track ending in (rear grip limited) spins... I hope I'm wrong!😒
Owen.C93
Owen.C93
177
Re: McLaren MCL36
Blackout wrote:
13 Feb 2022, 10:58
Regarding rear suspension integration, it wont be that hard to put the suspension elements inside the 'bell housing' IMO. This old Bar Honda Gbox has done it, and only the heave damper stayed outside.
https://i.imgur.com/85K4JOR.jpg
@DawnTreaderEng
Yes the turbine will occupy a big part of that space. But take a look at this 2014 Lotus gearbox. It's bell housing had to host a full turbo, not just a turbine, but still, the suspension elements (missing here) sat behind the turbine and exhaust pipes.
The split turbo obviously needs a smaller recess in the bell housing, so the inboard suspensions should have more space :)
Do you have the image of the lotus gearbox. Your post had the same image twice :)
jjn9128
778
Re: McLaren MCL36
Fer.Fan wrote:
13 Feb 2022, 13:56
dandfx wrote:
13 Feb 2022, 13:25
Found on Reddit
At the rear yes, but the Aston has the outlets in the middle. The McLaren is more controlled but the aston allows the coke to be tiny at the rear.
#aerogandalf
AeroDynamic
349
Re: McLaren MCL36
The rear diffuser is covered up.
Gotta say, love the McLaren Logo on the back of the rear wing. Wish Ferrari did the same with their iconic Ferrari text Logo.
Re: McLaren MCL36
GTO99 wrote:
13 Feb 2022, 02:04
mcjamweasel wrote:
12 Feb 2022, 01:45
To control spending IMho.
To control tyre wake, you could give the teams a regulation on wheel covers, but of course it will turn into a spending spree to find the best performance. The same for the wheels. 18 inches is big and presents a vast amount of space for all manner of complex channels and structures for aero, brakes an temperature controls. Again another spending spree.
NtsParadize
NtsParadize
Re: McLaren MCL36
PlatinumZealot wrote:
13 Feb 2022, 15:19
GTO99 wrote:
13 Feb 2022, 02:04
mcjamweasel wrote:
12 Feb 2022, 01:45
Cost shouldn't be an issue with the cost cap
