autogyro wrote:Just to make it absolutely clear for the non aero people reading this thread.
Reducing down force also reduces drag, which in turn reduces wake turbulance.
That is totally wrong.
Drag in F1 is mainly of two form, induced and profile drag.
Induced is for a given amount of downforce, dependent on aspect ratio while profile drag is dependent on effective profile (AOA, stall conditions etc..).
What you mix with is low downforce setups that have lower TOTAL drag, but do not reduce wake at all for they to have less finess than high downforce settings.
Hopefully for us...we can create planes/cars with more lift/downforce without adding or even reducing drag...if not then we wouldn't have all those different designs.
This thread brings nothing more than conjectures from people that do not know the topic they're discussing...
I too do not master the complex topic of overtaking in F1 and if you read my posts you'll see nowhere i've offered one solution to cure the problem but only correct people when pretending things wrong scientifically.
You may not like downforce, that doesn't make you right.
