Ferrari F2012
elFranZ
Re: Ferrari F2012
an interesting analysis of last week GP, from Luigi Mazzola, former Ferrari test team chief.
http://www.blogf1.it/2012/03/28/focus-g ... strategie/
EDIT: I'm at work so no translation, sorry guys.
Jersey Tom
Jersey Tom
Re: Ferrari F2012
Absolutely amazes me how objectivity goes completely out the window here.
f1316
f1316
84
Re: Ferrari F2012
I have to say I see no reason to believe that there's a problem with the front suspension - the team have been completely honest about their problems this year and have, in all areas, shown that their public statements correlate with the track performance of the car.
However, I do not have the engineering expertise to be able to state a personal preference over which type is better.
All I would say is that I see no disadvantage in reverting to the kind of suspension the rest of the field have anyway - it's not like they'll be losing out to anyone, or will have missed an area of performance that the others have. Is it not the case that the aerodynamic (for those who don't care for abbreviations) or CofG (for those who do!) benefits are not particularly large? It seems, therefore, sensible to remove this variable from the equation.
bhall
bhall
244
Re: Ferrari F2012
The front suspension is a variable only in the eyes of a small, but vocal, group of people outside the team. Otherwise, it's clear to most folks that the F2012's problems are aerodynamic in nature (and might relate to to the car's setup, but that's just my own feeling.)
raymondu999
Re: Ferrari F2012
Well it didn't have problems in the wet. Wet races usually disregard aero deficiencies and put more light on mechanical deficiencies. Which is why I'm not convinced it's the front pullrod.
On the topic of front pullrod though. I wonder if McLaren with their lower nose should have gone with that direction. It seems much more in line with their nasal concept.
失败者找理由,成功者找方法
Jersey Tom
Jersey Tom
Re: Ferrari F2012
f1316 wrote:All I would say is that I see no disadvantage in reverting to the kind of suspension the rest of the field have anyway
This is the whole point... there's nothing fundamentally different about F2012's front suspension compared to the rest of the field.
elFranZ
Re: Ferrari F2012
I believe our friend Crucial_Xtreme has something to share with all of us :)
scarbs
scarbs
393
Re: Ferrari F2012
I'm not sure who these vocal journalists are talking to in the paddock, but every technical person I've questioned to reaffirm my understanding of the Pullrod-vs-pushrod says there's as good as no difference between them. Its true the loads in the upright and top wishbone are greater and these feed into the chassis. This is a well known by-product of pull-rod and won't have escaped Ferrari when designing this. motion ratio is the same, there's a great deal of misunderstanding in how the pullrod articulates. Although the horizontal pull-rod looks intuitively wrong (& I admit that was my initial assessment of the set up), Its not its angle to the chassis, but the angle to the adjoining wishbone. which is the same for push and pull rod.
With the car suffering under braking\traction, poor in slow turns but good in high speed turns, Suggests Ferraris problems are likely to be aerodynamic pitch sensitivity, causing the downforce balance to shift under braking and acceleration. Exhaust location and or front wing design is likely to a factor. But equally any angle or radius on any surface affecting the flow under the car, could be creating an unexpected vortex and upsetting the flow. Although I've heard whispers the FWEP dealing with the wider Pirellis may be a specific factor ;)
Perhaps where people are now getting confused, is that with pitch sensitivity you need to alter the cars set up to reduce the problems. such as more heave stiffness to minimise attitude changes, this in itself causes handling issues which may be what some observers are seeing as the root cause, and not a symptom.
munudeges
munudeges
-14
Re: Ferrari F2012
Crucial_Xtreme wrote:Image
I think that diagram nicely sums up the problems. Put yourself in the position of that pull-rod and look at how little movement, especially vertical movement, there is inboard here. The stresses are greatly increased.
It's impossible to guess exactly what issues might be going on with the Ferrari, but it's relatively easy to visualise where that whole 'flexing the chassis' statement might be coming from. The suspension simply doesn't have the required level of compliant movement no matter how you orient it.
bhall
bhall
244
Re: Ferrari F2012
scarbs wrote:I'm not sure who these vocal journalists are talking to in the paddock, but every technical person I've questioned to reaffirm my understanding of the Pullrod-vs-pushrod says there's as good as no difference between them.
That sounds similar to what I've been saying.
(Yes, I'm shameless.)
EDIT: FWEP?
amouzouris
105
Re: Ferrari F2012
scarbs wrote:I'm not sure who these vocal journalists are talking to in the paddock, but every technical person I've questioned to reaffirm my understanding of the Pullrod-vs-pushrod says there's as good as no difference between them. Its true the loads in the upright and top wishbone are greater and these feed into the chassis. This is a well known by-product of pull-rod and won't have escaped Ferrari when designing this. motion ratio is the same, there's a great deal of misunderstanding in how the pullrod articulates. Although the horizontal pull-rod looks intuitively wrong (& I admit that was my initial assessment of the set up), Its not its angle to the chassis, but the angle to the adjoining wishbone. which is the same for push and pull rod.
Thank you scarbs!! Now the problems with the F2012 are much clearer....and i hope this puts the front pull-rod argument to an end!
f1316
f1316
84
Re: Ferrari F2012
I stress that it's not my opinion that there is any problem with the suspension - in fact I am far more convinced by the arguments on this forum for the retention of the current layout than those against it.
Nevertheless, I also can't see the harm in being exactly on the same page as the rest of the field, unless of course the suspension layout is fundamental to whole design philosophy of the car (albeit, a philosophy which has already shown itself to be flawed).
According to James Allen, this whole conversation may be academic, as it may not be possible to make the change:
"Engineers from rival teams say that it will be hard to get the car to the same level as the pace setting McLaren as the decision to go with pullrod front suspension has been shown not to be effective and the team are committed to it now. Time will tell."
amouzouris
105
Re: Ferrari F2012
If i'm not mistaken pitch sensitivity can be a problem when running the wings at an angle they weren't designed for...they are running the cars with much less rake than intended with the original exhaust solution...so solving the exhaust problem will give a lot of benefit...am i wrong?
Crucial_Xtreme
Crucial_Xtreme
404
Re: Ferrari F2012
Yes thank you very much Craig!! :D I too agree with Amouzouris, personally I think it ends the discussion.
To add to Scarbs analysis, I asked former Ferrari employee Luigi Mazzola his opinion on the front pull rod suspension and he said it was a red herring. Other than Gary Anderson, there aren't many technical analyst that think the pull rod front suspension is a problem.
Rough translation:
I would prefer focus more on the Aero of the suspension, which ... amount to very little. The pull rod is a red herring.
scarbs
scarbs
393
Re: Ferrari F2012
munudeges wrote: I think that diagram nicely sums up the problems. Put yourself in the position of that pull-rod and look at how little movement, especially vertical movement, there is inboard here. The stresses are greatly increased.
I'll reiterate, for a modern F1 suspension set up, rod movement for a given wheel displacement, for either pushrod and pullrod is the same.
