Ok I'm italian so I can do a recap of the article. It start with the 2015 problem Honda had, battery, turbine not working at the correct speed, the MGU-H, the overheating problems and the low efficiency of the energy transfer from MGU-H to MGU-K.
Then there are some infos about the 2016 PU:
* The layout will stay pretty much the same.
* They redesigned the turbocompressor (made in 2015 and for this season by IHI), the battery, the cooling system and both MGU.
*After the tests on dyno they had good results on power, also thanks to Mobil, they recovered most of the 30 bhp ICE gap but they are still not on par with Mercedes and Ferrari.
* There are still urgent reliability issues to solve.
* Both MGU-H and MGU-K are still not as efficient as Mercedes and Ferrari while they are generating power.
* The energy transfer are still not as efficient as Mercedes, and they say something I'm not able to translate 'cause I don't have the technical knowledge
("Tutte queste “trasformazioni” di corrente elettrica, realizzate grazie all'uso di un inverter, sarebbe preferibilmente eseguirle a voltaggi elevati per evitare problemi dal punto di vista termico. Honda ha provato ad alzare i propri voltaggi, cercando di superare i 500 V (Mercedes lavora quasi a 700 V)" = "All THESE " Transformations " of electrical current , realized through the use of an inverter , would preferably execute a High voltage for AVOID Problems from the thermal point of view . Honda tried to Raise their voltages , Trying to Overcome the 500 V ( Mercedes works almost a 700 V )". Thanks Google Translate). This is causing reliabilty issues.
The article ends with some consideration about Ferrari and Honda: the reliability issues can harm pretty badly their season with just 8 days of testing.
I hope Wazari can confirm or dismiss this post.
