Mercedes AMG F1 W03
skgoa
skgoa
Re: Mercedes AMG F1 W03
IMHO it's very unlikely that this meager amount of air is used to directly cool the engine. There are huge water and oil coolers in the sidepods for this exact job. An air inlet in that region would typically be for KERS cooling. An actual photo of this inlet would be nice.
edit: Found a good photo from Monaco!
Crucial_Xtreme wrote:Great shot of the W03 today in Monaco
It's "simply" an inlet in a pretty neat (low drag/turbulance) position. Look at the lower end of the splitter, almost where it touches the tea-tray.
Owen.C93
Owen.C93
177
Lotus have a little hole on the front of the vertical splitter for this.
Owen.C93
Owen.C93
177
Not sure if they're getting rid of the cascade for Canada or just haven't fitted it yet. I think the cascade helps with drag anyway to direct flow from the front wheel so it seems an odd place to try and remove some DF.
Also, splitter:
FakeAlonso
MercAMGF1Fans
MercAMGF1Fans
more details
techF1LES
176
Reshaped brake drum openings:
beelsebob
beelsebob
85
techF1LES wrote:Reshaped brake drum openings:
[img]https://p.twimg.com/Au3vM8VCEAEaW3x.png:large[img]
What's different?
Reason: Removed image quoted from earlier post
Byron R
Byron R
In the picture of the rear of the car, is that a monkey seat? ( in line with mechanics left leg) Is that picture from Monaco or this weekends race? I would've thought the monkey seat was for Monaco only. If that's what it is.
MercAMGF1Fans
MercAMGF1Fans
What's different?
Square-ish holes on the drums as opposed to "Arched"
The_Truth
The_Truth
What's different?
Could be the view angle, doesn't it?
beelsebob
beelsebob
85
The_Truth wrote:Could be the view angle, doesn't it?
Haha, if that's the view angle, I'll eat my own butt cheeks.
techF1LES
176
@beelsebob @The_Truth: Look at three openings atop of the brake drums covering upright assembly, these holes are wider in Montreal and also arched outboard. It's obvious from the pictures...
beelsebob
beelsebob
85
techF1LES wrote:@beelsebob @The_Truth: Look at three openings atop of the brake drums covering upright assembly, these holes are wider in Montreal and also arched outboard. It's obvious from the pictures...
Yep indeed, no idea how my eyes didn't see the first time... No idea how The_Truth thinks it's the camera angle.
MercAMGF1Fans
MercAMGF1Fans
:lol: :lol: u can clearly see the D-shaped holes on the canada spec
