We do not know for sure that they can not simulate the exhaust flow in the tunnels. There are ways to use gas burners, but is the cooling capacity of the tunnel able to disipate this heat gain?Chuckjr wrote:With all the millions of dollars they have for r&d, why on earth can they not make some sort of pulsing fan or something to simulate an exhaust in the wind tunnel model?
Exactly; they're saying "our tunnel and CFD models are also twitchy, slow and razor edge to tune, and we can't fix it".bhallg2k wrote:OR...
The team is completely full of sh*t when they report that "correlation between the wind tunnel, CFD and the track are fine."
(If you believe they don't have issues in that realm, it pretty much forces you to believe that they don't know what they're doing.)
An ingenious proposal.Chuckjr wrote:Ok excellent. That really helps.
With all the millions of dollars they have for r&d, why on earth can they not make some sort of pulsing fan or something to simulate an exhaust in the wind tunnel model? Why is it not possible to make some sort of wind generating motor under the models casing (which would be hollow I assume) blowing through a 60% exhaust toob at the side pod exits? Surely something could be built to accurately simulate this? Could they not also attach a heater to it (like a million dollar blow dryer or something) so heat mapping/effect could also be modeled? Or are these reduculous considerations?
Just seems that would save them countless hours guessing on the track.
It would make some technical sense as the nose needs to come down anyway with new rules in 2014, when the pull-rodFakeAlonso wrote:Than the F2012 will look great. I would like to see something similar, not necessary copy Mclaren. Unfortunately I don't think they will do that.xpensive wrote:The F2012-B will be a red MP4-27, perhaps with an even lower nose to keep the pull-rod, but with a decent geometry?marcush. wrote:x,I´m well aware of this .
And to be honest i think the pull rod is not their main problem...but then alonso already bagged his win of the year already so what...
The points haul upto now would justify forking out the money to design a new tub which is essentially what they´d need .
I guess someone already suggested that idea in the early days of testing.Chuckjr wrote:LOL
I know there is a regulation that the last bit if the exhaust pipe has to be seen. Would it be legal to use some sort of thick anti burn plexiglass and bury the exhaust pipe in the tunnel of the Acer duct directing the entire output downward right in the sweet spot, and even though the pipe faces 10% up its entire output is still directed downward. That would be legal because you can see it through the high temp plastic. Sorry if that's a reduculous question.
Oh my, why not MP4-13? You kept repeating that Ferrari should change pull-rod for push-rod, is it now that they must have flatter angles at the wishbones? Well, where is some sense in that, but a lot of cars this year and last year all have funny angles and seem to cope with it.xpensive wrote:At timbo; Try to dynamically simulate the low-nose MP4-27 geometry and I will comment on that.
Xcept for those with pull-rods that is?timbo wrote: ...
So, once again, you said pull-rod have less movement than pull-rod, I shown it is not true. What's wrong with pull-rod?xpensive wrote:Xcept for those with pull-rods that is?timbo wrote: ...
