Ferrari F2012
amouzouris
105
Re: Ferrari F2012
bhallg2k wrote:
Chuckjr wrote:
Postmoe wrote:That situation ultimately led to a non diffuser-sealed car [...]
[...](I believe I read in here the Acer ducts extend further down than any other solution by a large margin), how much improvement on track in time will this provide in your estimation?
Secondly, is that hope/determination the reason they are so convinced this design will come to them, and will offer a huge advantage later in the season?
The diffuser works, else the car wouldn't be as quick through fast corners. "Sealing" the diffuser will mean that the car's suspension/rake can be set up as intended, which should go a long way toward curing traction and top speed issues.
The altered angle of attack of its aerodynamic surfaces could also solve the F2012's instability woes.
+1 that's where my hopes lie!!
Lycoming
Lycoming
106
Re: Ferrari F2012
If that is true (and its a very plausible theory IMO) then they should focus on the exhausts. I don't think there's many other options if you need to seal the diffuser. I suspect if they can solve their pitch sensitivity problems, they will be able to run softer suspension too.
Postmoe
Re: Ferrari F2012
Chuckjr wrote:
Postmoe wrote:That situation ultimately led to a non diffuser-sealed car with poor rake and an enourmous amount of drag, pitch sensititvity and no rear DF at low speeds. That is consistent with the high drag and low rake theory. The car has a bad gasses extraction in the rear and it simply won't work at low speeds, when the wing DF is also poor and dependent on how the car is switching its CoG and its DF CoG.
It seems to me data in Oz was crucial, as their handmade approach gave some results and they decided to make a big step in three thirds during three races, acording to surprisingly accurate twitter rumours.
I think that they will seal the diffuser at all means, because no car has reached a 2010-2012 superiority. What rivals have done is finding a decent level of DF in a straight way to have a good relative aero efficiency. Not a lot more.
That makes incredible sense. Thank you for that explanation.
You state that Ferrari are determined to seal the diffuser and no car has done this very well yet. This implies that in your view the Macca and Sauber solutions are not actually doing much by way of sealing and are just doing a real good job with basic aero and suspension sets? Should that indeed be the case, and Ferrari do indeed seal the diffuser (I believe I read in here the Acer ducts extend further down than any other solution by a large margin), how much improvement on track in time will this provide in your estimation?
Slow down, I don't make any estimations, won't do it and don't know anything about the real situation :wink:
I'm only trying to put the pieces of information we have in a logical way. The low rake stiff rear theory combined with the acer ducts area issues has for me a certain consistency as a hole explanatory theory. Ride control isseus (banned solutions early in pre-season) also has sense.
What I figure in my head is that the diffuser is able to work and thus be sealed at high speed, extracting efficently high energy flows and sucking the car rear axe down in a normal way. But when the car hardbrakes and tractions the DF is very inconsistent, the car stalls in the front and looses DF in the rear, the aero CoG, wich is different than the mechanical one, changes brusquely and the entry and exit of some turns is a nightmare. The car is a kart in these moments and that's why FA is almost competitive and Felipe don't. You don't have solid front axe grip with a kart, don't need it. You just slide being confident in your ability to find early traction in a neutral entry.
I don't know nor understand what Macca and Sauber have done, but it seems that their approach was more straight aerodynamically. Strangely their not so injected exhaust flows seems to fit. Why? I don't know. Perhaps because they don't burn, literally, the tyres. It's also important to remember that cooling in the F2012 shares exit with exhausts. Perhaps overcomplex interactions made the rear fluxes overcomplicated and unpredictable. What if the flows are sticking perfectly, like a tight dress, at high speeds but suddenly become floppy and loose when breaking? I'm specifically pointing towards the sidepods and their slight U shape.
That's were I feel the problem is.
hardingfv32
hardingfv32
Re: Ferrari F2012
timbo wrote:What makes you think that total repackaging of the front on the existing tub (you don't think they can design, bake and crash test a new tub in 3 weeks time?) is a viable solution to a hypothetical front suspension problem?
Are they allowed to under the rules?
Brian
hardingfv32
hardingfv32
Re: Ferrari F2012
Postmoe wrote:I'm only trying to put the pieces of information we have in a logical way.
Have you developed a plan for a set of problems that does not exists? Ferrari's performance problems, how were they determined? Any data or just observation?
Brian
hardingfv32
hardingfv32
Re: Ferrari F2012
Postmoe wrote:I don't know nor understand what Macca and Sauber have done, but it seems that their approach was more straight aerodynamically.
Based on other discussions of the McLaren exhaust design on this forum, I would say the consensus is that your understanding is incorrect. McLaren is making a very good 'attempt' to seal the diffuser and that Ferrari is not.
Brian
bhall
bhall
244
Re: Ferrari F2012
Then why on Earth did you ask this question yesterday?
hardingfv32 wrote:How are you able to isolate the performance problem to the exhaust layout? The exhaust layouts of the entire field are varied with no one cars performance standing out relative to last year performances.
(This forum is not a contest; there are no winners.)
xpensive
xpensive
214
Re: Ferrari F2012
Let's try this another way, when McLaren opted for that lower and more tasteful nose on the MP4-27, any of you tifosi who
thinks they didn't consider a pull-rod, that they were too ignorant, arrogant or plain stupid to do that?
Of course the most resourceful team in F1 considered that option, but even with the lower nose they went with the push-rod,
when Ferrari found the pull-rod advantageous even with the highest nose in the pit-lane?
One of them got it wrong, I wonder who?
Re: Ferrari F2012
:roll:
still love the idea of pull ..but i certainly do not believe in ferraris interpretation of it.
why not having a rocker type top wishbone solution ? back to the 70s X what do you think?
xpensive
xpensive
214
Re: Ferrari F2012
marcush. wrote::roll:
There you go =D> , any pictures of the Lotus 79 front suspension anyone?
Chuckjr
37
Re: Ferrari F2012
Ok. This is really helping me understand. Thank you for your time.
Since the car can handle high speed corners well as shown through track time comparison to faster cars,  the thought is this...when wind pressure and mass become strong enough (through forward momentum) the diffuser behaves as though it is sealing either well or fairly well, but the unpredictability of the car surfaces when these forces decrease or cease and it is the action of this force release that causes the dysfunction of the car. This is unpredictable because the aero release is subject to constant variables like wind, ambient temps, tire stickyness, corner apex, track abrasiveness, corner differentiations, etc, all of which change organically and without any way of static measurement and this is what makes it so incredibly difficult to map out to resolve.
This explains why it may work well in lab settings (computer screen or a wind tunnel) which do not suffer these variables, and not translate to the track.
Are those somewhat  correct assimilations of your theory? If so this clearly shows why they can't fix it quick and the hope that if they can the car will really work well.
Can anyone explain why the car is so slow in the straights? The above may somewhat explain their cornering issues but what gives on their pathetic straight line speed?
Watching F1 since 1986.
Re: Ferrari F2012
straight line speed is a function of drag coefficient times crosssection and how you gear the toy as there is a rpm limit as you may run out of revs rising your terminal speed ,something we saw last year with DRS.
Of course the exit speed and when you can feed full throttle has huge influence on trap speeds ...take your choice :mrgreen:
hardingfv32
hardingfv32
Re: Ferrari F2012
xpensive wrote:One of them got it wrong, I wonder who?
As far as front suspension design... neither!
What shred of evidence of leads you to your conclusion?
Brian
hardingfv32
hardingfv32
Re: Ferrari F2012
Chuckjr wrote:Since the car can handle high speed corners well ..... what gives on their pathetic straight line speed?
Can it be as simple as they are running more wing?
Brian
bhall
bhall
244
Re: Ferrari F2012
xpensive wrote:[...] when Ferrari found the pull-rod advantageous even with the highest nose in the pit-lane?
All the more reason to opt for the lower CofG of a pull-rod suspension, chief.
I'm sure no one considered a return to a pull-rod rear suspension until Red Bull blew the cobwebs off of that idea a couple of years ago. Now it's ubiquitous to F1.
