RET? do you have the whole interivew?Brian Coat wrote:In RET this month Rob White was asked if MGU-H power is about 90kW: "You are in the ball park and have the right number of zeroes" or words to that effect.
Gnomic as usual but implies < 100 kW?
Probably no shock given you'd only need 120 kW in order to run round at full load with no braking!
There is... I think your concept of heat is why you say that. Heat is the transfer of internal energy. That heat is used to expand the gas as it flows through the turbine. A portion of the energy sued to turn the turbine is impulse (from the momentum change of the gases) and the other portion is from what we call "reaction" which is energy that comes from the gas expanding due to it's heat content as the pressure drops across the turbine. There is even something that is called "Blade-reheat" which is actually the friction from the turbine blades reheating the gases - this has even been shown to add a litle more efficieny. There are even some people who inject fuel into the exhaust (anti-lag?) in an effort to spin the turbines faster. Heat is very important to a turbine. A turbine is very much a device that absorbs heat. The temperature drop of a turbine is significant. Just preventing you from spreading more misinformation.Tommy Cookers wrote:there is no such mechanism
there is a mechanism that transforms some of the exhaust pressure or velocity into electrical energy
About 250 *C.Frank_ wrote:so, as a result of the exhaust gasses expanding when they exit that tight volute (turbine inlet) there is a temperature drop, 100deg c maybe ?
@ PZPlatinumZealot wrote:There is... I think your concept of heat is why you say that. Heat is the transfer of internal energy. That heat is used to expand the gas as it flows through the turbine. A portion of the energy sued to turn the turbine is impulse (from the momentum change of the gases) and the other portion is from what we call "reaction" which is energy that comes from the gas expanding due to it's heat content as the pressure drops across the turbine. There is even something that is called "Blade-reheat" which is actually the friction from the turbine blades reheating the gases - this has even been shown to add a litle more efficieny. There are even some people who inject fuel into the exhaust (anti-lag?) in an effort to spin the turbines faster. Heat is very important to a turbine. A turbine is very much a device that absorbs heat. The temperature drop of a turbine is significant. Just preventing you from spreading more misinformation.Tommy Cookers wrote:there is no such mechanism
You are both right. There is one mechanism that transforms some of the heat energy in the exhaust into exhaust pressure and/or velocity. (Called isentropic expansion). There is a second mechanism that transforms some of the exhaust pressure or velocity into electrical energy. (Called a turbine + MGUH)PlatinumZealot wrote:There is... I think your concept of heat is why you say that. Heat is the transfer of internal energy. That heat is used to expand the gas as it flows through the turbine. A portion of the energy sued to turn the turbine is impulse (from the momentum change of the gases) and the other portion is from what we call "reaction" which is energy that comes from the gas expanding due to it's heat content as the pressure drops across the turbine. There is even something that is called "Blade-reheat" which is actually the friction from the turbine blades reheating the gases - this has even been shown to add a litle more efficieny. There are even some people who inject fuel into the exhaust (anti-lag?) in an effort to spin the turbines faster. Heat is very important to a turbine. A turbine is very much a device that absorbs heat. The temperature drop of a turbine is significant. Just preventing you from spreading more misinformation.Tommy Cookers wrote:there is no such mechanism
Ambient pressure means 1bar absolute.PlatinumZealot wrote:You are talking about a gas that is already flowing through the turbine? Or an initially stagnant gas? Tell me so I can illustrate for you if you don't understand. I am always happy to explain these things. No problem.
that makes a lot of sense gruntgurugruntguru wrote: You are both right. There is one mechanism that transforms some of the heat energy in the exhaust into exhaust pressure and/or velocity. (Called isentropic expansion). There is a second mechanism that transforms some of the exhaust pressure or velocity into electrical energy. (Called a turbine + MGUH)
I think you have answered your own question. At 125k rpm (F1 limit for MGUH), 8 Nm of torque gives 105 kW.Frank_ wrote:that makes a lot of sense gruntgurugruntguru wrote: You are both right. There is one mechanism that transforms some of the heat energy in the exhaust into exhaust pressure and/or velocity. (Called isentropic expansion). There is a second mechanism that transforms some of the exhaust pressure or velocity into electrical energy. (Called a turbine + MGUH)
with regards to power consumption of the actual compressor tho (did you state 100kw somewhere ?) most turbo,s connecting shafts are only 5 or 6mm dia, so how can a 400hp disco potato 6mm shaft transmit so much power through it ? (albeit @ 150k rpm)
