I wouldn't take it to the bank. The man has a long history of indecisiveness, mass-dampers, DDDs and what not.marcush. wrote: ...
whiting has without a doubt heard of these measurng methods ..
A spannerman.
Install three mandatory sensors in the wing, one in the central section one in each wing tip, that measure the height above the ground using a laser. Teams use similar devices during testing to measure ride heights, I'm sure that they could find a way to incorporate them into the wings. Use the SECU to record the heights at all three locations throughout the race and report it back to the FIA. Another couple of sensors could be used strategically on the floor to make sure that it's not flexing.xpensive wrote:I believe that with today's knowledge in anisotropic materials, the only way for the FIA to keep up would be to test respective body-component in the wind-tunnel. But then you have the technical limitations of the FIAs representative in these matters, Charlie Whiting, who is little more than an x-Brabham spannerman.
You set him up against the Neweys, Simons and Gascoynes, ah well.
but this would mandate the measurements for both sides plus a reference ,to be able to quantify things ...toó much ..(car rolls ,heaves, pitches ,you got the variable of tyre vs pressure + pickup+ wear...)myurr wrote:Install three mandatory sensors in the wing, one in the central section one in each wing tip, that measure the height above the ground using a laser. Teams use similar devices during testing to measure ride heights, I'm sure that they could find a way to incorporate them into the wings. Use the SECU to record the heights at all three locations throughout the race and report it back to the FIA. Another couple of sensors could be used strategically on the floor to make sure that it's not flexing.xpensive wrote:I believe that with today's knowledge in anisotropic materials, the only way for the FIA to keep up would be to test respective body-component in the wind-tunnel. But then you have the technical limitations of the FIAs representative in these matters, Charlie Whiting, who is little more than an x-Brabham spannerman.
Alternatively, and maybe more practically, they could use a flex sensor placed along the full width of the wing and length ways along the floor to make sure they're not flexing too much. Something like these: http://www.active-robots.com/products/s ... orce.shtml
Well, by using electrical wires you can easily heat the object, as you know electricity comes with heat, so using the right voltage can generate the wing to loose rigity.xpensive wrote:For the sake of argument wesley, how would this heating be performed and what is the composite matrix which responds to it?
