Ferrari 150° Italia
govind112
Re: Ferrari F150
diffuser pics?
Doing It Again 2014
Formula None
Formula None
Re: Ferrari F150
Tim.Wright wrote:Very cool,
The active rear Santander device in action
Tim
Behold! The incredible disappearing sponsor logo!
forty-two
Re: Ferrari F150
ringo wrote:seems to be activate through the strut not the endplates?
Though there was was something taped on the endplate here:
look near the floor as well, exhaust temp strips.
Isn't it a pitot tube?
forty-two
Re: Ferrari F150
govind112 wrote:diffuser pics?
There are a few earlier on in the thread. If you search my posts you'll find one with a high res image.
forty-two
Re: Ferrari F150
Tim
Indeed, as I just noted on the previous page:
forty-two wrote:Initially, when I saw the ARW actually in it's moved position I thought to myself "hmm, I can't see the sponsors being too happy with their billboard being placed at an oblique angle". But then I thought about it a little more and realised, for the first few races at least, the fans are going to be fixated on that thing just waiting for it to move, so actually it works in favour of whichever sponsor gets their name on that thing.
forty-two
Re: Ferrari F150
ringo wrote:look near the floor as well, exhaust temp strips.
Is that what I previously described as red stripes in a 45 degree cut exhaust exit? They were definitely not visible in the enveiling shots, and the actual outlet appeared to be covered with a CF panel.
Re: Ferrari F150
andrew wrote:
Just_a_fan wrote:A new flexi-wing controversy in the making... :wink:
Are you implying that Ferrari will have an illegal device on their car, despite all their shouting against the double diffuser in 2009 and their rants against Red Bull last year?
:o Who could think that Ferrari might be anything but whiter than white?
forty-two
Re: Ferrari F150
Just_a_fan wrote:Just had a thought about the suspension cables on the F150 rear floor. What if they're designed to allow the rear floor section to lower slightly and thus make the diffuser work even better.
Oooh, interesting! I can just imagine the thread now!
But surely, if something which only works in tension (cable) was being used to hold the floor in place, it could fail a floor deflection test IF the FIA decided to mandate one.
If Ferrari were to be accused of this, the FIA would of course move quickly! (tongue firmly in cheek!)
Re: Ferrari F150
@42
Stranger things have happened... :wink:
forty-two
Re: Ferrari F150
Just_a_fan wrote:@42
Joking aside though, I don't think there are currently any deflection tests in that area are there?
Not sure how a floor (at the back) which could flex up but not down would be of benefit at the moment.
Personally, I think it's not finished or they're saving something tasty for Bahrain.
Re: Ferrari F150
forty-two wrote: Not sure how a floor (at the back) which could flex up but not down would be of benefit at the moment.
The idea was that the stays might alow downward flex at speed which would place the floor nearer the ground. The nearer the ground the better it works.
It was a rather tongue in cheek suggestion really.
Which probably means it's right...! :wink:
forty-two
Re: Ferrari F150
Just_a_fan wrote: The idea was that the stays might alow downward flex at speed which would place the floor nearer the ground. The nearer the ground the better it works.
Granted, but a cable stay only normally works in tension, so I suspect that there might be scope for the floor to flex upwards, but not perhaps downwards. While I agree that allowing the floor to move closer to the floor might be beneficial, I can think of a couple of wierd ways in which allowing it to move upwards might help. For example, remember the bendy bib of the RB6 which allowed them to get away with running super low without wearing the plank, well what if Ferrari have found a similar trick?
Unless of course the Scuderia have developed elasticated steel cable. If so, I want some!
Re: Ferrari F150
A look under the engine cover.. the exhaust headers seem to have irregular cross sections to allow close packing.
The engineer (or mechanic) is examining the suspension mechanism. Can anyone guess how it is?
right click >> view image
forty-two
Re: Ferrari F150
Where did this image come from n smikle?
Re: Ferrari F150
I captured it from this video:
[youtube]http://www.youtube.com/watch?v=H1Jw9W3C ... r_embedded[/youtube]
