Red Bull RB8 Renault
FrukostScones
162
Re: Red Bull RB8 Renault
The article in the AutoMotorundSport mag issue 14 /2012 on page 161 says: Red Bull runs this construction (the illegal flow through hub) since beginning of the season. Michael Schmidt (author and Germany's best F1 journalist) then goes on: The FIA did notice it only now.
I don't know if this is true.
http://www.formula1.com/news/technical/ ... 0/969.html
yeah they knew it was there since spain?, but the purpose was maybe not clear to them.
Owen.C93
Owen.C93
177
FrukostScones wrote:
bhallg2k wrote:One would think that if the splitter has enough contact with the ground to hinder top speed and require additional cooling for friction that the plank would likely lose through wear more than the maximum 1mm allowed during a race. That's not to say that there isn't anything "tricky" going on with RB8's tea tray, but I think the car's lack of top speed is simply a reflection of the downforce it makes, because downforce always equals drag. Such a trade-off is easy to make with class-leading downforce levels that don't put the car at an especially significant disadvantage in terms of top speed.
Is this correct? I thought floor/diffuser downforce is for free and also can reduce drag.
Maybe the car is just not very efficient. In the aero/downforce-part of Barcelona it was not the fastest.
I think the rake of the RB car may have a part to play, a diffuser which produces a certain pressure drop with zero rake gives lots of DF with little drag, while a raked floor will produce low pressure below the floor and also slightly behind it.
radosav
radosav
about red bull shutting down 4 cylinders in slow corners: is the fuel from those 4 cylinders pushed in the exhaust pipes and burned there providing some sort of exhaust blowing?
i think that with the different combination of 4 cylinders being shut down you can achieve constant exhaust gas blow.
alogoc
alogoc
-10
radosav wrote:about red bull shutting down 4 cylinders in slow corners: is the fuel from those 4 cylinders pushed in the exhaust pipes and burned there providing some sort of exhaust blowing?
missfire?
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
radosav
radosav
missfire?
well i don't know, i posted it to hear thoughts of members if it is possible.
Robbobnob
Robbobnob
They use the reduction in cylinders for torque control in low traction events, for example accelerating out of a hairpin.
Aswell as reducing thermal loading and fuel consumption, it mainly allows the driver greater control of the amount of energy he puts through the rears to stop them spinning up!
Yes the non used cylinders will have a mass flow through them, however the volume flow contributed to the exhaust stream will be insignificant compared to the volume flow from the utilized cylinders.
therefore their will be no added benefit to the exhaust flow stream from the shutdown cylinders.
raymondu999
Does anyone remember if they tried their V2 tunnel in Canada? I know they tested it in Barcelona and Monaco free practice.
I wonder if Newey will still stay fixated on the tunnel, or if he will abandon that and look for other avenues of performance.
失败者找理由,成功者找方法
hardingfv32
hardingfv32
Running on for cylinders..... If they want less power in the turn, the driver must do it with the throttle. Why would you want the engine to drop cylinders when you can simply close the throttle?
What am I missing?
Brian
raymondu999
Are you asking about whether the regs should be changed to disallow this, or what benefits this 4-cylinder trick actually brings?
失败者找理由,成功者找方法
thisisatest
thisisatest
i wonder if cutting 4 cylinders, with the other 4 having larger throttle openings and more fuel, is more fuel efficient, or smoother in power delivery. im under the impression that fuel injectors are most precise in the middle range of their duty cycle? does the engine run slightly cooler, allowing a smaller radiator package?
hardingfv32
hardingfv32
raymondu999 wrote:Are you asking about whether the regs should be changed to disallow this, or what benefits this 4-cylinder trick actually brings?
You can have an engine map that calls for cylinder cutting at a set rpm, but it is going to be controlled by the throttle position. So then what is the point of cylinder cutting? You want less power, just lift off the throttle.
Brian
raymondu999
Perhaps it is speed related? With the 4 dormant cylinders only "waking up" at a set speed, above the traction-limited threshold?
失败者找理由,成功者找方法
e30ernest
e30ernest
27
It might be difficult to drive that way specially when trying to balance the car on the throttle. Drivers may be expecting X amount of power going through and end up getting Y. I agree with Brian that lifting/throttle modulation would work better in this scenario.
raymondu999
I think it's to allow for a more responsive throttle map at higher speeds, but to allow for more drivable torque on slow corner exit. The two aren't necessarily mutually exclusive, but with pedal travel so minimal in F1 anyways, it wouldn't hurt to help the drivers.
失败者找理由,成功者找方法
hardingfv32
hardingfv32
raymondu999 wrote:Perhaps it is speed related? With the 4 dormant cylinders only "waking up" at a set speed, above the traction-limited threshold?
Of coarse the engine has no way to know where the traction limit is.
Remember the throttle map does not have to be linear. There can be spots with very little slop.
Brian
