230
That's not the engine, looks like the ordinary engine we've had for some time now.
467
ringo wrote:That's not the engine, looks like the ordinary engine we've had for some time now.
I suppose it would look similar to the curent engine from the rear (and without the turbo).
matt21
86
The new Renault engine will be called "Energy F1"
Blanchimont
Blanchimont
214
Forza
238
ScarbsF1 wrote:How the RB9 might look with the new @RenaultSportF1 2014 engine fitted (obviously not the '14 aero rules)
Wow, the box (inlet manifold) looks smaller than I thought but the intercooler looks biiig. How will the engin's oil and water rads look ? it's nice they covered the exhaust manifolds with CF like RBR did in 2011
matt21
86
Anybody an idea, why the covered the exhaust in carbon fibre?
djos
113
Wow, nice!!!
"In downforce we trust"
Forza
238
Tech specs of new Renault Energy F1 - 2014
Gantt chart of powerplant development
Source: RENAULT REVEALS RACE-INTENT 2014 POWER UNIT: THE ENERGY F1-2014 PRESS KIT - PDF
Huntresa
Huntresa
Nice and easy exhaust exit aswell all to follow 2014 rules :D
Blanchimont
Blanchimont
214
matt21 wrote: Here´s the presskit:
http://www.renaultsport.com/IMG/pdf/rsf ... final2.pdf
On page 4 and 5 of this PDF file, you can read that the fuel quantity per race is limited to 100kg. The 2014 Technical Regulations do not contain this limit, only the 100kg/h flow rate is mentioned.
timbo
timbo
111
matt21 wrote:https://pbs.twimg.com/media/BNR5UZqCcAEpvm_.jpg:large
Probably to prevent heat loss and make turbine more effective.
Blanchimont
Blanchimont
214
timbo wrote: Probably to prevent heat loss and make turbine more effective.
That would also be my guess, but is there carbon fiber available that can withstand the temperatures right at the beginning of the exhaust pipes?
Owen.C93
Owen.C93
177
RBR used to run a carbon shroud around them. Image
