Ferrari F2012
Tim.Wright
330
Re: Ferrari F2012
Belatti wrote:I dont get how will they make that front suspension to work...
The geometry is actually not so extreme. Its a normal rear axle pull rod rotated about 30deg. Thanks to JT for pointing that out to me initially.
Scarbs, Ive used a picture of yours. Let me know if thats not ok.
bhallg2k wrote:With the move to pull rods, would it make any sense to link the front suspension?
How is camber effected by pull rods?
The answer to both of your questions is that the pull rod changes virtually nothing from a pure suspension point of view. Save for some slightly different compliances, the kinematics of a pull rod are the same as a push rod.
imightbewrong
imightbewrong
Re: Ferrari F2012
The cockpit air duct for electronics and driver cooling?
Lurk
Re: Ferrari F2012
But forces applied on the tyres & suspension aren't rotated by 30°..
Echo
Re: Ferrari F2012
Why have Ferrari changed the air intake above the head? I mean the 2009 & 2010 & 2011 ferrari´s were round intakes but know it´s a bit like Mercedes W01 intake, rectangular.
Rich teams should only be allowed to win
Tim.Wright
330
Re: Ferrari F2012
No, you are right, the forces are still acting from a ground refrence, but the force characteristics of a double wishbone suspension have very little to do with the the pull/push rod. The upper and lower wishbone angles determine how much contact patch force goes into the push/pull rod.
In anycase, what I was demonstrating was that kinematically, the motion ratio is not as bad as one might think when they see a horizontal pull rod.
Tim
italian
italian
Re: Ferrari F2012
From 43.30:
[youtube]http://www.youtube.com/watch?v=Qw9aN4bZ ... e=youtu.be[/youtube]
Another great job of Scarbs! :D
"Two things are infinite: the universe and human stupidity, but about the universe I still have some doubts." Albert Einstein
Pierce89
Re: Ferrari F2012
bhallg2k wrote:How is camber effected by pull rods?
push or pull rod should not effect camber control much.
StrFerrari4Ever
Re: Ferrari F2012
Who was the guy explaining the technical aspects of the F2012.
raymondu999
Re: Ferrari F2012
The guy in the video I posted? Tombazis
失败者找理由,成功者找方法
StrFerrari4Ever
Re: Ferrari F2012
raymondu999 wrote:The guy in the video I posted? Tombazis
Cheers, his accent is awesome =D>
FW17
184
Re: Ferrari F2012
imightbewrong wrote:The cockpit air duct for electronics and driver cooling?
Everyone seems to be convinced that this is a pull rod, but to date i never seen a pull rod that is so bulky. Why should a tensile member be so large? there is also no point in making the aero cladding so big
Love the way the camera pods are mounted in the FIA control zone. They have made a mockery by using it to create downforce rather than the intended lift. They could have made it even better by making the wing mounts wider like i the jordan and benneton of the early 2000s Image
KevinR34
KevinR34
Re: Ferrari F2012
flynfrog
Re: Ferrari F2012
how would you make a push rod work in that geometry? Its probably just faired for earo.
Re: Ferrari F2012
it's over designed because of the shallow angle and the chance that it can take a side hit during racing methinks.
Gui59
Gui59
-1
Re: Ferrari F2012
Those pictures of the front are reveling one thing no visible otherwise,there is a hole in the floor just at the bottom of the sidepods, if somebody can highlight it, this would explain the story about the work they did on the floor.
