Nope. look again. Mercedes HAS a single cross section. Lotus visible has TWO cross sections.dans79 wrote:it has to be a continuous cross section 50mm (I think) back from the tip. Since the lotus 'tusks' aren't connected one has to be longer than the other so that when a cross section is calculated they only get one area and not two. Since the Merc 'tusks' are connected, you will get one continuous area that looks like an upside down U.Pup wrote:turbof1 wrote: So if Merc are within the regs here, why did Lotus have to do the asymmetrical thing? Would Merc not also have to lop 50mm off one side?
There is no need for Mercedes to make the nose tip asymmetric because IT IS one single U shaped cross section 50mm behind it's tip.
This shape nose is closer to what the FIA intended in the first place. It fits more to the rules than the single and double phallic noses that we see being hung from the other cars.
