Renault Sport F1 R.S. 18
F1Krof
95
Re: Renault Sport F1 R.S. 18
Sevach wrote:
14 Sep 2018, 16:48
https://pbs.twimg.com/media/DnD_mxxXsAY_b-8.jpg
Very Red bull like.
I'd say very Mercedes like.
Wroom wroom
Via AMuS
via Albert Fabrega
Via @AlbertFabrega
Dipesh1995
Dipesh1995
104
Crazy amount of detail around the bargeboards.
carisi2k
27
Morteza wrote:
04 Oct 2018, 15:42
https://pbs.twimg.com/media/DopGgbFU8AASM8X.jpg
Via @AlbertFabrega
slow boat vs a fast boat
Neno
Neno
-29
Dipesh1995 wrote:
04 Oct 2018, 20:09
https://cdn-8.motorsport.com/images/mgl ... -18--1.jpg
too bad it doesnt work.
DinkLv
DinkLv
62
Dipesh1995 wrote:
04 Oct 2018, 20:09
Looks like they're testing two versions SPLEF (SidePod Leading Edge Flip-ups) around the sidepod inlet at the same time. By the way I strongly doubt the longitudinal cuts at front half of the bargeboard footplate are used to counter incoming flow from the outside to the inner surface of the bargeboard, in order not to let air rush in through the gap between the footplate and ground. The bargeboards create strong suction when placed too close to the ground, generating upwash right under the monocoque, which is not ideal. As a result, if you could generate some outwash around this area, creating a strong boundary condition to counter the incoming flow, it will probably form an effective seal and thus is an effective solution. Working on Formula SAE diffusers and trying to counter act inwash generated by parts in front of the rear wheel. The inwash hits the tyre and create large tyre squirt areas going straight into the diffuser. Tried solutions similar to this and shows effective seal, though no improvement in numbers (not optimized yet).
232
Neno wrote:
05 Oct 2018, 02:35
Dipesh1995 wrote:
04 Oct 2018, 20:09
Well it could actually be working really well and be compensating for another weak area of the car.
Neno wrote:
05 Oct 2018, 02:35
Dipesh1995 wrote:
04 Oct 2018, 20:09
How are you so certain it doesn't work?
Neno
Neno
-29
wesley123 wrote:
05 Oct 2018, 21:26
Pretty easy actually. 12th and 16th place in Sochi. Both cars lapped at least once. Other one got lapped twice. When cars updates work they usually go up in standings and get best results.
For further confirmation we have Hulk's statement after Sochi Renault lost out in F1 development race. That's plenty of evidence supporting my statement.
Neno wrote:
06 Oct 2018, 04:00
wesley123 wrote:
05 Oct 2018, 21:26
How does that mean their bargeboard setup doesn't work?
Dipesh1995
Dipesh1995
104
Dipesh1995 wrote:
04 Oct 2018, 20:09
Not sure if anyone noticed but the sidepod flow conditioners and deflectors on each side of the car are different in that image. The right hand side is the latest red bull inspired set up and left hand side is the old version.
