basti313 wrote: ↑22 Sep 2019, 11:42
NathanOlder wrote: ↑22 Sep 2019, 11:03
basti313 wrote: ↑22 Sep 2019, 09:13
Strange interpretation. If you look at the track improvement during Q3 it easily gained 0.5sec. Many drivers even improved by a second.
Means Vettels Q3 lap was still much better than what the others delivered on pure pace. There is nothing wrong with his pace.
The simple issue is that Vettel does not deliver anymore perfect second runs in Q3 like he did against Webber in the Redbull. This is his problem for him since he lost the diffuser blowing.
So with an extra half second from the track evolution (no way that much) in his last run, must have been so shocking, he was driving like Palmer??
Did you look at the Q2 and Q3 timing? Obviously not...the track was developing like crazy.
And yes, Vet bottled his lap badly...in many corners. Just like Ves on his second, Ham in his first run and Bot in both runs. We only saw clean laps from Leclerc.
And did I look at Q2 to Q3, yes of course I did. And here also makes your "half second evolution in Q3" ridiculous!
Everyone knows the top teams use their "party mode" in Q3, no need for it in Q2, and they limit its use to save engine wear.
So Q2 to Q3 , you have a small amount gained in the PowerUnit ,then add to that the drivers will wring every little bit out of the car they can, they will give it everything because now it really matters. So if the track evolved as much as you say in Q3 alone, the difference from Q2 (likely lower engine modes, and slightly less risks by the drivers) to Q3 must be in excess of 1.5 seconds ? (if the track evolves half a second in Q3 alone and higher power and risks)
So lets look at the gaps for the drivers in Q2 and Q3.....
Leclerc 36.6 -- 36.2 so 4 tenths.
Hamilton 36.9 -- 36.4 so 5 tenths.
Vettel 36.7 -- 36.4 so 3 tenths.
Max 37.0 -- 36.8 so 2 tenths.
Bottas 37.1 -- 37.1 so nothing.
Albon 37.8 -- 37.4 so 4 tenths.
Some of those gains will be the car , lets say 1 tenth through extra power, and the same for the drivers wringing the neck out of the cars. So we can knock 2 tenths off for those.
Now the differences are
Leclerc 2 tenths
Hamilton 3 tenths
Vettel 1 tenth
Max 0 tenths
Bottas 2 tenths slower
Albon 2 tenths.
So after looking at this, please spend time to explain where you feel the track evolved by half a second in the 10minutes between the first and second run in Q3 please, as I have spent time showing how that is likely to be wrong.
Charles and Lewis did the best job in Q3, and they were rewarded.
