Mercedes W11
LM10
LM10
122
Re: Mercedes W11
The tyres clearly move when he pushes and pulls the steering wheel. Even if that's not doing adjustments to suspension system, it surely is actively influencing aero. Both cases would be illegal.
Re: Mercedes W11
This appears when he pulls the steering wheel
Via @Danny10_DotCom
Gilles27Kimi7
Gilles27Kimi7
25
Re: Mercedes W11
Predator
Re: Mercedes W11
It looks like the wheels toe-in as the steering wheel is pulled back then toe-out / back to neutral as it's pushed forward.
Sawtooth-spike
Re: Mercedes W11
LM10 wrote:
20 Feb 2020, 11:55
Bet there argument will be that the wheel already does adjust the aero when you turn the wheels, so they are just adding a new element
Its a good idea that its pulling back to engage, that way it returns to the normal state as the drive brakes
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
Formula Wrong
Re: Mercedes W11
Oehrly wrote:
20 Feb 2020, 11:53
Could they maybe argue that it is not changing the suspension but "steering" the front wheels individually?
Good question, though usually "steering" involves turning both front wheel into the same direction. Other teams will surely protest this.
It's a genius invention for sure, but I'm wondering if, in case this somehow IS legal, next year's rules can be adjusted still?
If you no longer go for the space someone always has to leave, you're no longer a racing driver
izzy
izzy
Re: Mercedes W11
zibby43 wrote:
20 Feb 2020, 11:49
jjn9128 wrote:
20 Feb 2020, 11:46
From the regs.
10.2.3 No adjustment may be made to any suspension system while the car is in motion.
Not sure how this is legal.
By that same token, Mercedes had to know this would be spotted, so I’m guessing that they have an argument that it very much is.
yes, i mean what is an "adjustment" exactly? It could be argued that an adjustment is something that stays adjusted, as opposed to something that moves dynamically like all the suspension. The steering wheel is supposed to move parts of the suspension, after all!
Mark4211
92
Re: Mercedes W11
Morteza wrote:
20 Feb 2020, 12:01
https://pbs.twimg.com/media/ERNd8vzU8AIk2je.png:large
Via @Danny10_DotCom
He's pressing the 'MARK' button, can be seen with his right thumb. This sets a remark in the Telemetry when reviewing
LM10
LM10
122
Re: Mercedes W11
Sawtooth-spike wrote:
20 Feb 2020, 12:06
LM10 wrote:
20 Feb 2020, 11:55
Turning the wheels is a must on every car on earth, if you don't want to crash into an object at some point. Pulling and pushing the steering wheel is known for airplanes, but surely not cars and I don't see how that could be legal as there must be adjustments to the suspension system in order to do that movement to the tyres, which, as already pointed out, is illegal under movement.
izzy
izzy
Re: Mercedes W11
i wonder if the purpose is to lower the front on corner entry, more than change the toe-in which is just a side effect. That was the original idea of the offset track rods wasn't it, then FIA limited it to 5mm
Sawtooth-spike
Re: Mercedes W11
LM10 wrote:
20 Feb 2020, 12:13
20 Feb 2020, 12:06
LM10 wrote:
20 Feb 2020, 11:55
They would not be doing it unless they had some kind of arguement why they believe it's legal. As I said they will base this on the wheel already adjusting aero / suspension of the car.
I am sure it will be protested and we will get to hear there interpretation of the rules and why they think it's legal.
drunkf1fan
drunkf1fan
Re: Mercedes W11
It's pretty funny watching Will and the other guy absolutely missing the tires move and not getting why it's exciting so far.
It's a very big change if it's legal, might not make a massive difference but maybe enough difference. Scarbs has noticed it and thinks the rules may not in fact cover this particular setup.
djones
djones
Re: Mercedes W11
This would have taken a lot of development.
There is no way Mercedes would have invested the time and money on something that would be observed so easily unless they were at least 90% confident it was legal.
With the fancy rear suspension, this is pretty impressive from the team even if it's banned.
zac510
zac510
22
Re: Mercedes W11
It's possible they are doing this knowing it is illegal and with no intention to race it; by adjusting the suspension on the fly, they can save time compared to coming into the pits, adjusting the suspension and going back out again. Once they've collected the data of both variations, the engineers can work out which setting is preferred.
However I don't think that's what they're doing here because I'd expect Lewis to do a series of laps with the steering wheel in forward or back setting.
Juzh
161
Re: Mercedes W11
Scarbs is pretty sure purpose is to improve straight line speed by reducing scrub, as already pointed out by some people here.
He also thinks it's probably legal due to it being a steering related trick, not a suspension one.
