Aston Martin AMR22
jagunx51
185
Re: Aston Martin AMR22
is that the same part ?
Mat-tes
Mat-tes
30
In his McLaren video Kyle engineering gave an explanation as to maybe why the Aston Martin brake ducts are so large.
It's not possible anymore to blow the wheels, but apparently (according to his saying) if ducting inside the cake tin passes a certain regulatory line, you can channel it back out. There's not much pictures to based that on but looking around I think he might be right, the duct look to end in an opening at the rear.
That's something that will be easy to spot/debunk once testing is ongoing.
Blown axle used to help clean the tyre wake, so there might be some benefits in using a similar idea but on the inner side of the wheels with the help of the new brake strakes.
He speaks about that possible solution here at around 9 min.
Owen.C93
Owen.C93
177
Rear brake ducts already do this. Albeit angled up slightly to match the rear flicks.
Hoffman900
Hoffman900
219
Are those demo tires? I thought they had to run treaded tires for filming days?
Owen.C93 wrote:
12 Feb 2022, 17:59
Indeed
motorsport.com - F1i
Dont you think that the FIA could ban these, (if teams abuse them and put them in places FIA doesn't like), on the grounds of safety... ...under the pretext that the mechanics could cut themselves :?: :lol: :arrow:
Mchamilton
Mchamilton
Blackout wrote:
13 Feb 2022, 12:16
https://i.imgur.com/Cl5V8YU.jpg
Theyll probably ban them simply because they serve no other purpose than an aerodynamic affect that the rules were intended to eliminate, its creating the y250 vortex in a cheeky way
Different view on the tea tray
AeroDynamic
349
Scarabs analysis :)
AeroDynamic
349
Tea tray
Mansell89
Mansell89
So is there a reason why the Aston has that tubbier, more rotund rear before it tapers at the last second versus McLaren, who have that well known, slimline coke bottle that has become synonymous with most Mercedes powered cars?
Is it more to do with that pronounced undercut that is dictating airflow differently?
timbo
timbo
113
Mansell89 wrote:
13 Feb 2022, 23:06
Yes
Mansell89 wrote:
13 Feb 2022, 23:06
Yes. Because they cannot place radiators and intercoolers in the usual place (all the way to the floor at an inclination), they have to lift them and span them almost horizontally.
jagunx51
185
232
This car could dow with some flow straighteners on top of the sloping sidepods. But i doubt its permitted.
Looks good so far. The concept should result in more airflow to the diffuser, But it also results in more surface drag and possibly more lift from the body.
siskue2005
70
ringo wrote:
14 Feb 2022, 01:52
And also higher centre of gravity
