Intake Valve and Feliks' ideas
Feliks
Re: Intake Valve and Feliks' ideas
Ramjet symulation (upper green) Need Java
http://www.grc.nasa.gov/WWW/k-12/Virtua ... gnsim.html
As I see massive construction that are to demolish the building of Reactor No. 3 is me shivers go ..
Certainly the building suffered the most, because it was the biggest explosion. So the walls are certainly very weak, and it seems to me that the water in the pool of fuel remains a miracle there is to do there can not be inspected, that does not mean that the building is sturdy ..
Therefore, demolition should in my opinion not cause additional shocks, and be carried out as gently as possible ... Heavy construction equipment, rather they should not be used ...
They are after all modern methods, such as cutting concrete with water. The company offers cutting up to 3 meters ..
[ur]http://ajaks.eu/en/services-for-civil-e ... obots.html"]http://ajaks.eu/en/services-for-civil-e ... obots.html[/url]
I do not want to think what would have happened, if as a result of the vibrations, the resulting leaks in the fuel pool and the water came out of it ... Almost as a result of radiation inside the building and its three filling remains, you can not to re-seal it. ..
Therefore, even mild disturbances such methods may be used: diamond cut rope ..
http://www.hilti.com/data/editorials/-1 ... et%20e.pdf
https://www.hilti.co.uk/fstore/holuk/te ... 0%20en.pdf
http://www.youtube.com/watch?v=lZ04OdpmJ84
http://www.youtube.com/watch?NR=1&featu ... 54madabs9s
http://www.youtube.com/watch?NR=1&featu ... VI8Z5grdOw
http://www.youtube.com/watch?feature=en ... 8xoHvhiA2k
Andrew
WhiteBlue
92
I wonder what the intake valve issue has to do with Fukushima. Can someone explain?
superdread
superdread
16
WhiteBlue wrote:I wonder what the intake valve issue has to do with Fukushima. Can someone explain?
I think it's more on the ideas side of "Intake Valve and Feliks' ideas".
It should not be here any more, it's no discussion and more like Feliks' personal blog.
Feliks
Andrew :D
Feliks
Here, the photo of the engine and Abart, for those who have doubts about the hight engine of my..
Andrew:)
Feliks
Did you know that it looks like the latest engine to produce electricity using any fuel, such as coal dust. Attached to the treadmill, skip step steam,,,
The end of the treadmill must be about 1 Mach speed, which at the shoulder of 50 meters is normal ... every second ..
http://www.youtube.com/watch?feature=pl ... GcRgEuCocQ
It's not like we all have to fly, but the current a good thing ...
Regards Andrew :D
Feliks
Here is a reworked so as not to put unnecessary drag .. A bit like a UFO. Still on the edge of the "plate" can fasten some neodymium magnets ....
With these dimensions of 10 MW ....
In preparation for the new job of atomic physics, they can calculate the efficiency of the this power plant ...
Regards Andrew
Feliks
s you remember I really like windmills operating in the negative pressure .....
Here you have one type of renewable energy that can run on the negative pressure generated by the moving cars ...
http://www.new4stroke.com/cars.wmv
Andrew
This thread is legendary. This is a ball of inspiration if you actually read from the begining. Let it live.
Feliks wrote:Here, the photo of the engine and Abart, for those who have doubts about the hight engine of my..
Andrew:)
You need to put that on youtube, Felix.
Feliks
This treadmill UFO version of ramjet engines, would work best as an MHD generator. Its efficiency apparently comes to 60% or more has no moving parts. At 1 m plasma jet should be good.
The rest of you can generate in the traditional way, which would help stabilize the rotation ...
Andrew
Feliks
This model can be mounted on the ends of the arms windmill ....
http://www.youtube.com/watch?feature=pl ... 7c3zz0rWZM
Andrew
Maybe the exhaust manifold to the F1 wear a magnet and additional energy (electricity) have?
Feliks
Hi-Fi Wind Amplifier...
Regards
Santa Claus :D
Feliks
So interesting what you can find in my archives. The oldest Radioamator I found in my ...
Google translated :
"According to information published in one of the writings of English - has been developed by researchers at the concept of electricity generation by passage of ions and electrons with very high speed through a magnetic field
The practical implementation of this method that was based on Plasma gas forcing by the strong magnetic field. Electrical power of 1000 KW can be obtained by passing the said plasma at 3 times the speed of sound, the magnetic field of 1 meter long between the poles of a magnet at a distance from each other by about 15 cm. No, you would need the boilers and steam turbines. Previous experiments have generated so far a small amount of electrical energy. Achieving the full effect expected after several years of further intensive tests conducted"..
A song about Christmas Eve from Santa Claus :
http://www.youtube.com/watch?feature=pl ... MCZ4mjnLqs
Andrew :-({|=
coaster
16
If engineering was an artform, these ideas could almost be classed as surrealism.
