Hoffman900
Hoffman900
212
Re: Mercedes Power Unit Hardware & Software
Dbl post.
Hoffman900
Hoffman900
212
LM10 wrote:
22 Oct 2021, 19:13
dans79 wrote:
22 Oct 2021, 19:04
nzjrs wrote:
22 Oct 2021, 19:00
Another new engine for Bottas in Austin. What's the strategy here?
ICE only, 5 place drop only. most likely testing for next year.
Would they go for a 6. ICE just for testing reasons in such a tight championship, though? I’ve the feeling they’re really pushing the reliability limits. Would also explain their huge power jump lately.
Yes. Given the lack of testing outside of racing, and the 23 race calendar next year, the teams kind of have no choice but do some of this.
I’m sure they sweetened to the pot for Bottas. Maybe that’s what his new car prior to the announcement was about. :lol:
LM10
LM10
121
Marty_Y wrote:
22 Oct 2021, 19:14
LM10 wrote:
22 Oct 2021, 19:13
dans79 wrote:
22 Oct 2021, 19:04
ICE is a 10 place drop.
10 for the first replacement then 5 for each one after.
Yea, edited my post right after I heard that. Thanks.
atanatizante
115
dans79 wrote:
22 Oct 2021, 19:04
nzjrs wrote:
22 Oct 2021, 19:00
Yeah, I think so too ...
In the team thread, I wrote about "there are rumours saying that the 3rd spec PU was built with an eye toward the E10 biofuel that should be used in 2022. Thus BOT`s 4th PU at Monza was run with special mapping in order to see had they could compensate some 65HP that they`ll lose with the new fuel ...
The same rumours are also saying that 2021 Merc PU having to cope with more races/km than last year was wear out at a faster rate towards their end of the duty cycle than it was designed for and the reason for that is the fierce battle between them and RB/Honda, which forced them to use more and more aggressive PU mappings in races, all coming with some negative consequences: they have found some issues at the crankshaft and valve seats ..."
Jesus
dans79
267
atanatizante wrote:
22 Oct 2021, 20:23
This it the bit i find highly suspect, as the first PU did just fine.
It ran every free practice, qualifying session, and race for the first 5 race weekends. It was then relegated to fp1 & fp2 duty till Spa, so it did another 6 fp1 and fp2 Sessions.
The numbers just don't add up to me!
201 105 104 9 9 7
Hoffman900
Hoffman900
212
dans79 wrote:
22 Oct 2021, 20:31
atanatizante wrote:
22 Oct 2021, 20:23
I also suspect sources that are able to specifically specify what the problem is. Anything I can find is innuendo from mysterious or non existent sources.
toraabe
toraabe
Remember that from this year there is a limit on the test bench. Probably they want to test changes to the ice before 2022. So do it on the track......
jellybone
jellybone
dans79 wrote:
22 Oct 2021, 20:31
atanatizante wrote:
22 Oct 2021, 20:23
or they do if you have a different perspective of it, sure they were doing fine with the first power unit but at that time while in the hunt it was clear RB was getting the better of them. Last little bit Mercedes has found much more pace and that coincides with this sudden pu unreliability. Unless we are engineers on the team nobody can really know for sure but seems a very plausible narrative
Marty_Y
Marty_Y
'Few reliability issues' - Wolff
Toto Wolff told Sky Sports after first practice that the Mercedes-powered engines are experiencing some gremlins in the system this season.
"We have had, unfortunately since mid-year, a few reliability issues that keep coming back," the Silver Arrows boss admitted.
"I think we understand better what it is but it means there is no durability in running them."
atanatizante
115
dans79 wrote:
22 Oct 2021, 20:31
atanatizante wrote:
22 Oct 2021, 20:23
Both Merc and Honda had run their first spec in conservative/detuned PU engine modes in the first 7 races of the season, bearing in mind they have to do 22 races this year with just 3 PU and they also need to do some testing with the new E10 fuel for 2022 ...
Jesus
Wolff hinting that the problem compenents are very small but critical to engine operation. You have to break the engine seals to get to them. So might as well introduce a whole new ICE.
He hinted that it is a pneumatic component.
So fortunately, it is not combustion, structural or tribology related.
amho
write engine reliability fix, read cheating and increasing engine power.
There is no Might or Power except with Allah.
FDD
FDD
81
It is strange to me that Lewis's engine is not at risk
atanatizante
115
Is well known that this year we don`t have different spec PU, just PU no.1, 2 and 3, right?
Then, in my point of view, the only single parameter (fuel and lubes aside), that was responsible for lowering their reliability was the aggressive engine mappings they were forced to run after they introduced the 3rd PU ... and this theory was backed by Christian Horner, when he was asked on Sky by Jenson Button what was the cause of Merc`s PU failures ... he just said that Merc was forced to run such high engine mappings they didn`t run it before until this year ...
Jesus
billamend
billamend
Mercedes has been having problems since last year. Remember Perez engine in Bahrain and Abu Dhabi? And there was a rumor that they were running very conservative in Abu Dhabi because they were afraid of it blowing up.
