![Smile :)](./images/smilies/icon_e_smile.gif)
For the first time I'm sensing a bit of an inquest at Red Bull. Because of their performance advantage they haven't needed to look much at their drivers, but I'm convinced that if you put Hamilton or Alonso in Webber's Red Bull they would win that race. They're either going to have to gain a performance advantage again or have a look at their drivers, and that has political implications in itself where I'm not convinced the team has any control.n smikle wrote:The car is just not providing enough of a cushion for its drivers as it once was in the early parts of the season. Vettel and Webbers are guys that need that cushion.
No such thing as too much grip.raymondu999 wrote:Actually I remember saying it back then; and I'll say it again. I think RB miscalculated their Silverstone setup. They had too much downforce on! They were going through the first left right in Maggotts, as well as the Abbey right-hander (Turn 1) flat, with the DRS enabled! This would've meant that in the race (where DRS had to be off, giving them MUCH more downforce) they'd have way too much grip, and a shedload of drag to deal with on the straights.
Obviously I've never driven a formula one car, but for every motorsports there is the "rule" that there's never NO action on either pedal. There is full throttle, full braking and every possible iteration of pedal pressing inbetween, but never is the car just rolling through there. In F1 engine braking is very heavy, so if you'd just roll through there you'd lose a lot of speed. So if it's not full throttle, but no braking either, somthing between 20 and 80% of throttle will be applied. That means that the EBD wasn't affected by the change of regulations in that complex of corners.HampusA wrote:Actually it does.
You take the left hander - right hander flat then no throttle for the left hander and half the right hander and then you get on the power.
Yes you are correct that for 99% of corners there should be no delay between brakes and throttle. That´s why some drivers like Barrichello had to re-learn left foot braking instead of his usual right foot braking.Mandrake wrote:Obviously I've never driven a formula one car, but for every motorsports there is the "rule" that there's never NO action on either pedal. There is full throttle, full braking and every possible iteration of pedal pressing inbetween, but never is the car just rolling through there. In F1 engine braking is very heavy, so if you'd just roll through there you'd lose a lot of speed. So if it's not full throttle, but no braking either, somthing between 20 and 80% of throttle will be applied. That means that the EBD wasn't affected by the change of regulations in that complex of corners.
