I know this is off-topic and xpensive might get mad at me for replying, but this is just not correct in my opinion and it's a disservice to let people think it is.strad wrote:Yep...That's the reason for the short track settings that were mentioned. In the corner that tire that is leaning way over on the straight, is standing straight up mid corner.timbo wrote:I always felt camber is used to aid cornering by providing bigger contact patch in roll.
I would say camber thrust is attributed incorrectly to giving extra grip.munks wrote:Look up "camber thrust"; I believe that is the primary reason camber is used.
Not sure where you're going with this. From the data I've seen, it does seem to increase maximum lateral force somewhat in the direction cambered. Is that not generally true? And there's been suggestions that it generates lateral force "more efficiently" (generates less heat) than a slip angle producing the same lateral force. I have no data to back up the second claim, however.Jersey Tom wrote:I would say camber thrust is attributed incorrectly to giving extra grip.munks wrote:Look up "camber thrust"; I believe that is the primary reason camber is used.
Do people just pick and choose?Red Bull's static camber this weekend at Spa was over 4 degrees on the front tires. Do you honestly think that Red Bull's chassis was leaning over 4 degrees to get their outside front to stand up straight in the corners? I'll give you a hint: Pirelli was only worried about the tire joint on the inner edge.
You will sometimes (or even frequently) get more peak lateral force when you add camber, to an extent.munks wrote:Not sure where you're going with this. From the data I've seen, it does seem to increase maximum lateral force somewhat in the direction cambered. Is that not generally true? And there's been suggestions that it generates lateral force "more efficiently" (generates less heat) than a slip angle producing the same lateral force. I have no data to back up the second claim, however.Jersey Tom wrote:I would say camber thrust is attributed incorrectly to giving extra grip.munks wrote:Look up "camber thrust"; I believe that is the primary reason camber is used.
But yes, there are other positives and negatives to using camber.
Short track settings are where you'll find NASCARs running the insides at +8 degrees (or at least they did a few years ago). I really don't think those tires are flat on the ground.strad wrote:Do people just pick and choose?Red Bull's static camber this weekend at Spa was over 4 degrees on the front tires. Do you honestly think that Red Bull's chassis was leaning over 4 degrees to get their outside front to stand up straight in the corners? I'll give you a hint: Pirelli was only worried about the tire joint on the inner edge.
Look, I said that was short track settings,,not road course.
We're ready to learn here! But just so you know where I'm coming from:Jersey Tom wrote: However, the mechanism for the increased grip is what I would not attribute to "camber thrust" - which is something I associate to a completely different F&M aspect.
We were through the Italic on another thread, long before you became a member munks, where one scool of thought (mine incitentally) was that contact-patch area is simply vertical load over tyre-pressure, which in that case would suggest the same for a cambered vs non-cambered wheel.munks wrote:You're a mysterious man, JT.
But since the empirical evidence says that tire spring rate typically decreases with camber, I suppose that means you'd probably get more rubber overall on the ground. That might be counteracted slightly by a more uneven load distribution, but I couldn't say for sure.
xpensive wrote:We were through the Italic on another thread, long before you became a member munks, where one scool of thought (mine incitentally) was that contact-patch area is simply vertical load over tyre-pressure, which in that case would suggest the same for a cambered vs non-cambered wheel.munks wrote:You're a mysterious man, JT.
As I recall, the debate was over the influence of the tyre-wall's stffness.
