Donuts wrote:The purpose of this thread is to get an exact description of the start and to undertstand how much influence the driver has on the start.
How can Mark Webber be that bad?
I for one thought that most parameters were established by the engineers, the driver only has to rev up and when the time comes, put in the first gear. Voilá!
Can somebody who knows(not "I think so") or has the time to find out the drivers start procedure step by step(starting with warming up the tyres on the out lap). Maybe we can find a video of a start with the speed, rev, brake and gear display. We can continue discussing the different parameters(drivetrain, tyres an so on...) from an engineering point of view.
Maybe we'll get to the bottom of why Mark Webber is starting so much worse than Sebastian Vettel allthough they are in similiar cars...
Without traction control it´s not easy sending 700+ horses down to the ground
Especially in a car with so little torque.
Basically the driver during the weekend will do starts and feel how the clutch bites and checking how slippery the racetrack is etc.
Even if you have a certain idea on how to set the car up it´s still very much a gamble since you have 24 other guys also doing starts with probably slightly different settings and obviously different cars.
As far as Webber and starts... I think he just has to little revs.
Many times the car has bogged down and i have never seen him loose places in the start due to excessive wheelspin.
To get the perfect start you must first have some luck that your settings you chose is actually the best settings and choosing rpm limit on where you will dump the clutch etc.
What the engineers say can only go so far. In the end it´s up to the driver because he´s the only one actually knowing the grip levels.
The truth will come out...
